We have miss placed the cord to our leapfrog leappad item # 30056. We have replaced batteries but can't get it to come on so thought maybe we could buy a cord for it but don't know what size to buy.
SOURCE: Panasonic SCEN5 adapter
Where can you get whole unit for $49? If you answer I could
research the power requirements. If I recall correctly it has a
slightly odd power connector.
On the other hand would you be willing to sell yours? We have a dead remote :-(
SOURCE: Stylus Pen Broken: LeapFrog Explorer Smart Globe (Item Id: 40002)
Hello Sushil,
If in the US, Call their Consumer Services number at:
1-800-701-5327
They will be able to help you get a new one.
Thanks for using Fixya and consider rating this solution.
Wayne
SOURCE: Need to replace power cord to battery charger of cordless drill
it takes a 24V DC 200mA The one I have is a Ktec Model KA12D240020034U
SOURCE: Green Light turns off when plugged in to the computer.
hi bro what u need to do is ... understand when u plug in the ac adapter the light on the ac adapter goes off and whne u unhoook it it comes on .. right there is a possible static charge in the mobo bcoz of which the ac current is nt able to flo on thru the wires to the motherboard .. what u can do is turn ur laptop off completely unhook the ac adpter and take off the battery as well press the power button for 15 sec press and hold it do this xcersice .. hook every thing up and try to charge the battery again it should work .....second possible thing can be may be the connectors on the mobo can be bad on the pin in the prong on the ac adpter must be twisted ,,, so check for that as well ...if still no go then either problem with the onboard power connector on mother board or the whole mother board power aseembly IE replace the mobo ....
cheers
