Refrigerators Logo
A
Anne Henderson Posted on Mar 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Solving the last two corners of Rubics cube - Refrigerators
Brett Duxbury
Level 3:
  • Refrigerators Master 4,352 Answers
  • Posted on Mar 30, 2017
Brett Duxbury
Level 3:
Answers
4352
Questions
0
Helped
1118646
Points
13423
The cube began to spin badly after washing
google search
rubik's cube lubricant substitutes
A lot of the speed competitors add a lubricant to aid in speed solving
Can a cube be twice another cube?
Yes, but not with rational numbers.
a^3 = 2 * b^3 so
a/b = cube root of 2 which is an irrational number
So an approximate result is the nearest you get, pretty close but with an unkown exact result.
How do I set time on the Brookstone Ipod cube radio? Thank you
Simply HOLD down the "CLOCK SET" button for ~3 secs and the time will flash... Rotate the dial around the SNOOZE button to the hour you want; click the "CLOCK SET" button again for the minutes and rotate the dial again... Hit the "CLOCK SET" button one last time and you're done! Need help with solving real problems? Contact me at [email protected]
1helpful
2answers
What is the box with lightning bolt inside? turn on humidifier and just the orange light above this comes on but humidifier not working?
I looked at the Owners Manual for your humidifier online, but could not locate what you described.
However, it is manufactured by Homedics and you can contact their Customer Service Dept @
800-466-3342 Mon - Fri, 8:30a - 5pm ET for help in solving your problem.
How do i replace the serpentine belt on a 97 range rover
You loosen brackets on tensioners (they look like rollers) and belt slips off when they're loose. NOTE: make a note of how belt is routed before you take it off. If not it's like figuring out Rubics cube
Last year Lee's age was a square number and next year it will be a cube number . How old is Lee
This is more of a trial and error question, not a math question; however,
If Jason is 26, then last year he was 25 (5 squared) and next year he will be 27, which is the cube of 3 (3x3x3=27).
Got it?
-Gort.
Cant solve rubick's cube
Hello
OK, at the link below you will be able to get a step by step instruction manual on solving the cube.
Click HERE to navigate to page.
Hope this can be of help.
Kind regards
Andrea
Paper jam on a Cannon D760 copier
A technician who knows what he is doing is required to access the Canon fuser.
However, If you remove the glass on some later models there is an access hole wear you can get a long shank screwdriver down to the screw that holds the fuser in place. On some older models I have actually drilled a hole through the optics area to access the screw. You can get it with a stubby, but it is not fun. Getting the covers off is like working a rubics cube, good luck...
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
