SOURCE: frigidaire classic series. model
I have the same problem - the panel goes out every now and then. I just flip the breaker to kill the power, then restore it again a few seconds later, and all is fine aga (well you have to reset the clock). :)
SOURCE: I have a G1220SC model. F11 shows on the panel,
F11 is a drain error.
Water outlet restricted.
** Check for kink in the drain hose.
** Clean the filter combination. (p.41)
** Clean the non-return valve (check valve) (p. 53)
** Check/clean the drain
Unplug the machine.
Disconnectthe drain where it enters the S bend from the sink. You may find thenozzle into the S bend is blocked. Probe it with a screwdriver andclear the blockage.
Plug in the machine and re-try.
THIS MANUAL may not be for your model - however it will give instructions on some of the steps above.
If all checks out - the pump will need replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: During cycle...F11 is showing on panel. What does
F11 is:
Serial Communication Error
Communication between the
Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be
sent correctly.
Check for:
Check Wire Harness connectors to
the MCU, the motor, and Central Control Unit (CCU)
Check the Drive
system for any worn or failed components
Check MCU
Check CCU
Check
Motor
Check Wire Harness
If all the connections look fine ,
then its possible the CCU is reading wrong and will need to be changed
SOURCE: I have a Frigidaire dishwasher (Model #
Go to www.applianceart.com. They have stainless steel replacement panels and covers. They have covers for your fridge too.
SOURCE: I have a hotpoint
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
I appreciate your post, Dale Miller!
From what you have described your Frigidaire range is displaying an error code of "F11" and you are receiving an alarm. Normally an "F11" error code stands for a shorted keypad. I would suggest performing a reset and you can do that by flipping the household circuit breaker off for roughly ten minutes. If you restore power and continue to receive an "F11" error code you may need to replace your control panel. I would recommend having a professional do so, they will be able to properly disassemble your range and accurately replace the electrical component to not damage anything internally on your range. I hope this information is helpful to some degree. -Matt
I appreciate your inquiry, friend!
I see that you are having a difficult time with your Frigidaire range displaying an "F11" error code. That error code stands for a shorted keypad and I would recommend performing a reset on your range. You can do that by flipping the household circuit breaker off for roughly ten minutes. If you restore power and continue to receive an "F11" code you may need to replace the EOC (Electronic Control Panel) this is not a simple DIY job. I would recommend contacting a professional technician for proper disassembly and repairs to be completed. I hope this is helpful information. -Matt
