You just go to the link I attached I'm sure you will get the solution of your problem.
825i John Deere
SOURCE: Carburetor adjustments for FE250D engine in a John Deere Gator
generic carb adjustment, any adjusting screws, turn them all the way in the back out 1 turn. run the motor and adjust
SOURCE: 1974 John Deere 2030 diesel tractor and the engine dies
I will assume you have bled the fuel system per the owners manual to ensure no air lock in your system. This is especially critical after replacing the injector pump.
The next step is to ensure you fuel filters are good and flowing and last but probably the problem is the screen on the petcock (fuel shut off) in the fuel tank. Remove this shutoff valve and clean the screen with a fine wire brush and carburetor cleaner.
SOURCE: We have a John Deere lawn mower model JS45. Just
this problem is related to the auto-snesing carburator. If you wrap the throttle cable, that runs down the left side of the mower, around the handle several times and tie wrap in place the mower will run. I had the same issue with mine. the manual is vague at best when it describes how to fix. After you wrap the cable around the handle, it will tighten the cable and the mower will run.
JV
SOURCE: when starting John Deere 455 lawn tractor, runs
Unless you have a diesel, the black smoke at start up is not normal, it should be white if anything. It sounds like you are burning very rich, or no air at all, check the air filter, check the fuel cond, check the governor thing, make sure it moves freely and rebounds. Change the spark plug. I don't know what else it could be without being there. The carb could be clogged up, some carb cleaner wouldn't hurt. Hope this helps.
SOURCE: john deere L100 is not getting fuel to the engine.
Jdeer L100 fuel does not stay in fuel filter drains back to tank
