1997 Dodge Stratus Logo
w
william calhoun jr Posted on Mar 29, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1997 dodge stratus wont start has no spark and no trouble codes.
I just found out there was a automatic shutdown rely. Do you know anything about this rely?
old marine
Level 3:
  • Dodge Master 2,426 Answers
  • Posted on Mar 29, 2017
old marine
Dodge Master
Level 3:
Answers
2426
Questions
0
Helped
951776
Points
10742
The automatic shutdown (ASD) relay will turn off power to the coil(s) and fuel injectors if the PCM is not receiving a signal from the crankshaft position sensor. You can check the ASD relay, but the problem is almost always a crankshaft position sensor or the wiring/connectors between the PCM and that sensor.
2answers
Fuel pump has been changed but it will not start.
Search Results
    Dodge Stratus Questions - Car cranks but wont start ...
    www.cargurus.com > Questions > Dodge > Stratus
    CarGurusJan 2, 2015 - Car cranks but wont start - I have a 97 Dodge stratus i bought just a few days ago. ... just cranks but wont actually start. Its not the battery or ... the relay for the fuel pump as well. What could be ... wont start. 2003 Dodge Stratus.
    Dodge Stratus Questions - 2000 Stratus died and won't start ...
    CarGurusSep 7, 2013 - One day when I went to start my car it started up then as I went to reach ... anything to get it starting but he had thought it was the fuel pump but then it ... Ihave a 4 cyl 2.4l DOHC with 172,000 miles. Changed the oil on Sunday and on Tuesday it died while driving ... 2005 dodge stratus wont crank 1 answer.
    Electronic fuel pump problems and replacement- Chrysler ...
    www.allpar.com/fix/fuelpump.html
    A fuel pump failure will usually set no engine codes and you may get no ... Sometimes the pump will give you warning signs that it is about to go but you may not notice ...times on the tank and turn key to start again and listening for the pump hum. .... been through and you'll feel better later knowing that it has been changed.
    Replaced Fuel Pump, STILL NO START!!!!!!! - DodgeTalk
I have a 00 dodge stratus 2.5 how will bypass the antitheft circuit in order to start
Bypassing Neutral Safety Switch, Chrysler sebring 2000 ...
? 2:21
https://www.youtube.com/watch?v=uBszX3CnXeo
Apr 27, 2012 - Uploaded by Brianna Kufa
Bypassing Neutral Safety Switch, Chrysler sebring 2000. Brianna Kufa ... 1) Remove wiring harness attached to tranny. (there's 4 connections: ...
Part 1 -How to Troubleshoot a No Start (Chrysler 2.0L, 2.4L)
troubleshootmyvehicle.com > Chrysler > 2.0L, 2.4L
Dec 29, 2012 - Failed starter motor. Failed neutral safety switch. ... Dodge Vehicles: Avenger. 1995 ... Stratus. 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002.
Automatic Shutdown Relay - Allpar
3helpful
3answers
2001 dodge stratus 3.0l automatic cranks but wont start not even with start fluid
check the fuel pressure and make sure you got the correct pressure
3answers
My 1997 Dodge Stratus, standard, 2.0L had been rattling as i would accelerate. Well this went on for a few weeks and everything seemed fine with the car. It wouldnt make any noise while in neutral, only as...
Any rattles that come from an engine are not a good thing. This is most likely a catastrophic failure of a component like connecting rod, piston, valve rocker etc. Time for a new engine .
2001 dodge stratus 2.7L wont start. Starter, battery, fuel pump is good. Help!
Do the basic tests. If it cranks good but won't start, have a helper crank it while you check for spark at the plugs. If spark everywhere use a gage and check proper fuel pressure and fuel injector pulse.
Any applicable trouble codes?
5helpful
2answers
My 2005 stratus wont start turns over but doesnt start the trouble code is p0340 so i changed cam sensor and crank sensor still wnt start i need help so bad
2.4 L?REMOVE CAM SENSOR..CRANK ENGINE..MAKE SURE CAM IS TURNING..IF NOT..TIMING BELT IS BROKEN OR STRIPPED..NEW BELT SHOULD FIX PROBLEM..MAKE SURE YOU CHECK/REPLACE WATER PUMP/IDLER/TENSIONER
2.7L?REMOVE OIL FILL CAP AND SEE IF CHAIN IS MOVING..IF NOT..YOU HAVE COLLAPSED TENSIONER..YOU WILL HAVE SOME VALVE DAMAGE..LET ME KNOW IF TOU NEED MORE INFO
Dodge intreped no start
Have you checked the Automatic Shutdown Relay (ASD) under the hood?
1997 Dodge Stratus V6 oxygen sensor location
Upstream, as in ahead of the converter, back toward engine. Start at converter and work your way back, should be on exhaust pipe or even on manifold.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
