SOURCE: I turn my monitor off and it comes back on??
I would hook it up to a different Monitor to see if your monitor is broken.
If you mean you set the screensaver in the software and it keeps turning your monitor back on, then yes, its becuase you have it set to motion detection. Thats usually called an event & systems usually come out of screensaver mode & to display the event.
SOURCE: cant access lorex DVR from the internet
i have the same trouble, and i did what u said and it doesn`t work yet:S something else????
SOURCE: Can't log on remotely
did you set up a port to connect through if not you need to set one on the port your DVR needs and forward it. It is called port forwarding.
SOURCE: Lorex eco 130 can not get to menu, screen shows Lorex page
There should be a paper clip size hole somewhere on the back of the unit. If you depress the button in there it should be the reset. The problems sounds to me more of a hard drive issue though.
Testimonial: "I could not find a reset hole on the back or front of the unit. I also thought it was a hard drive failure, so replaced the drive. The system does not appear to see the hard drive the HHD light on the front is not on, but it was not on before I replaced the drive. All connections are tight. I was thinking there was a combination of holding the menu button plus another to reset the unit. Thanks in advance for any help"
