Garden Logo
B
Bob McDonald Posted on Mar 29, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I purchase blade bolt set CA09164 and felt caps and washer set CA09028S for old toe cutter victa lawnmower?
Bill Boyd
Level 3:
Top Expert:
  • Garden Master 53,816 Answers
  • Posted on Mar 29, 2017
Bill Boyd
Garden Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925908
Points
172802
I am sure that the bolts come with the blades as sets and there hasn't been a change since victa started
Talk with a mower shop as they have a selection of bolts and kits
Hello need to replace a blade drive belt on a victa vrx 14.5hp 38 inch cut
Replace the blade drive belt on a Victa VRX 14.5HP 38-inch cut lawn mower with the correct size. The old belt was 77 inches by 1/2 inches, but a larger new belt may not fit. Verify the size requirements with the manual or Victa customer support, or compare to the new belt purchased. If incorrect, return and purchase the right size.
Jan 28, 2023 • Garden
1helpful
I have recently been given a Victa Catch and Release Lawnmower,but no manual. How much oil do I put in before commencing use. And How do I drain dirty oil?
Victa catch and mulsh ?
search pops these up as 4 strokes
which model and a internet search gets you its user manual
start with 600 ml oil and top up as required
try not to over fill
look for drain plug up under blades or on the side of motor
Nov 06, 2016 • Garden
1helpful
I have a stigma lawnmower can someone please tell me WHY my bolts keep coming loose that hold the blades on thanks jamie
the blades are held on with a bolt and a nyloc nut and a flat or cupped spring washer
nyloc nuts are not to be reused
Sep 20, 2016 • Garden
Victa lawnmower manual 460 Pro
You want a manual for a victa or are you looking for an answer regarding a victa? If you want a manual then a good lawnmower dealer can probably help, if not you can try www.buyamower.co.UK or f.g.adamsons
Oct 14, 2014 • Garden
2answers
Are bolt cutter blades really sharp?
Manual bolt cutters usually have symmetrical V-edge cutting blades.
With the sharpening angle in the range of 20-30 degrees.
For comparison, the sharpening angle of the kitchen knife is less than 10 degrees.
With such a pretty blunt edge is impossible to cut your finger. But this is the best option for cutting thick metal rods or cables. Like this:
If it is interesting to read more information about bolt cutters, I recommend this review -
https://toolslaboratory.com/best-bolt-cutter-buyers-guide-2019
Can i purchase a metal cutting blade for my sovereign petrol grass trimmer 6102
Universal kits are available that will allow you to attach a brush cutter blade to just about anything that usually has a line head. The kit contains a selection of bolts, adapters, packing washers etc - you simply select the parts you need to attach the blade. The blade itself is not machine specific.
May 08, 2010 • Garden
1helpful
Need to replace to old blade with a new one on a rolux magnum laser lawnmower but don't know how the remove it
Disconnect the spark plug wire and ensure that the plug cap is some distance from the spark plug.
Remove the center cover cap (Pry off) and then remove the mounting bolt by turning it Counter clockwise while holding the blade to prevent rotation. Pull off the old blade and remove the center hub housing from the old blade. Transfer the center hub housing and install the new blade. Tighten the bolt CLOCKWISE while holding the blade until it is tight. Make sure you use a 6 point socket! Using a 12 point socket will result in the socket slipping and personal injury.
Re-connect the spark plug wire and your ready to mow again.
Thanks for using FixYa.
Kelly
Mar 07, 2010 • Garden
42 deck craftsman riding mower. how do you get blades off? md 91721880.
On most riding lawnmowers, you can remove the blades reaching underneath the deck while the deck is set to its highest position. This may not be possible on lawnmowers with three blades; however, most 42 inch mowers have two blades.
The blades are usually held on with either one or two bolts (on each blade). Oftentimes, too, there is a lock washer underneath the bolt.
If you have auto ramps, it might help to push the front end of the mower up on the ramps. This can give you more room to access the blade bolts.
If the blades have not been removed before, those bolts can be on really tight. You might need to use some kind of breaker bar on your wrench to give you more leverage.
Victa lawnmower
how do you replace the zip cord on a victa tornado last years model
Oct 12, 2008 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
