Golf Logo
Elizabeth Rehsif Posted on Mar 28, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wheres the ground go on healights on a ezgo 3 wheeler
Ronald Prier
Level 2:
New Friend:
  • Expert 101 Answers
  • Posted on Jul 03, 2017
Ronald Prier
Expert
Level 2:
New Friend:
Answers
101
Questions
0
Helped
145912
Points
158
Never had a ezgo 3 wheeler to work on before but sounds interesting. If this is an electric cart then wire ground to a negative battery that gives 12 volts from where positive is connected. If gas cart wire to frame or neg post of battery.
I installed a universal turn signal switch on my ezgo golf cart everything works but the indicator light don't work
As the bodywork is mainly grp make sure the indicator lights are grounded (earthed). This may require a ground wire from each indicator light back to the chassis or wherever the battery is grounded
Sep 24, 2019 • Golf
1helpful
Ezgo txt golf cart hesitates and looses power, yet shows full battery charge.
loose power connection or bad ground somewhere. get a little metal wire brush (or several of them), disconnect battery, and disconnect ground and power wires (keeping track of them), and start brushing them, then re-attach and test
What will cause a 1993 Ezgo golf cart to run good when wheels are off ground and stall out when on ground?
The engine is stalling due to too much load (torque) when it's on the ground. This most likely means a problem with a clutch or it's gearing.
Apr 01, 2019 • Golf
Ez-go golf gas cart only runs when rear wheels are off the gound, why?
It has a level switch that is broken or out of adjustment
3 wheelers tip. Is there a stabilizing bar with 2
Hello, There is nothing available from the manufacterer or comercially for this type of scooter.
Some Scooters have Castor wheels underneath the edge of the footboards but they are usually have a higher ground clearence.
3helpful
2answers
My healight and brakelight just stopped working on my 1999 sportster the bulbs are good
check the fuses and the ground wire to be sure you have a good ground otherwise lights often wont work.
Top Golf Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
vince
Are you a Golf Expert? Answer questions, earn points and help others
