Primer bulb? I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
SOURCE: My McCulloch MS1838AV 38cc chainsaw has a broken
only way is to "mike" out the bearing areas and connecting rod journal. compare the original to the replacement. close is not good enough exact is what you want.
SOURCE: Need to remove & replace primer bulb on mcculloch mac 3516
There are 4 different IPLs for this saw. Fuel detail are on multiple illustrations.
http://www.ordertree.com/modelinfo/MCC/22-600035-18-Mac-3516-IPL-211318-01/139.22-600035-18-Mac-3516-IPL-211318-01.1.59.1.html
A helpful video, a few of my suggestions, and a schematic follow:
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Take lots of notes and a few digital photographs to help with reassembly.
HTH
Lou
SOURCE: Did mcculloch manfacture the same piston rings for
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple. On the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I’ve found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Operator’s Manuals: are much more difficult. I’ve dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322 HTH
Lou
SOURCE: Looking for a Primer Blub for a Mcculloch PowerMAC
Hello Winston;
Even the new number you provided does not cross. Could your saw be a PM3216, model 11-600032-33? That does cross here:
McCulloch MTD
Chainsaws 32cc-35cc
and with better detail here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/MCC/11-600032-33-Mac-3216-06%2F93-IPL-211229/139.11-600032-33-Mac-3216-06%2F93-IPL-211229.1.59.1.html
See the "General Assembly" print; item 23; pn 224242-02.
M & D Mower
http://www.m-and-d.com/index.html
Has the above item available through arinet reasonably.
It follows:
http://arinet.lookupparts.com/AddToBasket.aspx?Qualifier=MCH&Name=224242-02&Quantity=0&SellerId=1017594&Username=Default
I am going to close this. We can continue to converse as before.
http://www.fixya.com/support/r3558917-mcculloch_chain_saw_ipl_illustrated_par
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
SOURCE: whats is the fuel ratio for a McCulloch MS1838AV
(25:1)
25 parts fuel to 1 part quality 2-stroke oil.
Hope that helps!
When the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
The pressure side of the primer returns displaced fuel to the tank as it is depressed.
To get your manual for your McCulloch chain saw, you need to call 1-800-521-8559, ask for parts, than ask for a PDF user manual,you will need the model number of the saw..
It will be e - mailed to you for FREE.
1-800-521-8559
MONDAY - FRIDAY - 6:00 AM - 4:30 PM (MST)
www.mccullochpower.com
Please take time to rate me
