SOURCE: I have an old Ford 550 digger clutch failure
if its a hydraulic clutch & conneted to the same system & its low on fluid then that will be your problem
just top it up & try it you may have to bleed out the system of air if it doesnt work!
SOURCE: JCB 801.4 mini digger - no control of digger arm
We have a similar problem on a Mitsubishi MM55SR.
We developed a new control set-up
SOURCE: Kubota mini digger KX36-2: changing rubber tracks
Undo the nut the nipple fits onto ,thats the valve itself.
Then lift up the machine with the arm over the side that the tracks off about 2 - 3 foot so it helps the track to go in and on and start putting the track on at the sprocket end first.
When you get the track to the idler end it will push the grease out as it rolls on or you can lever it home with a big bar before tracking up .
Testimonial: "Thanks for this, I've now got the rubber track back on & retensioned it. The track does need levering home with a bar and that was fairly difficult."
SOURCE: how do i replace a track seal in my mini digger.
Slack off the track adjuster valve, spin the track off and pull out the idler assy. The seal is on the end of the chrome piston just pull it out .
