Every time I have seen that, it is just the USB cable on the mother board in the back of the machine.
1. Shut off and disconnect the machine from power
2. Remove the rear panel
3. Remove the electrical panel cover
4. Find the USB cable on the bottom of the board all the way to your right.
Soft Serve Parts C713
SOURCE: Taylor Y754-27 Soft Serve Ice cream machine
gearbox is sealed, I've never replaced one.check belts could be too tight, does it scream when you start it. check bearing at end of barrel sharp edge means needs replacing. check temperature of product disspensed on loud side could be too cold. adjust on board or needs new probe, inexpensive but a ***** to install.
SOURCE: taylor 754-27 runs good until ice cream is made
It is possible that your viscosity is set too cold. You should check the temperature of your product to see if it is too cold. Is the Ice Cream hard? It sounds like maybe the beater overload is tripping. Some of the overloads can reset on their own. If you have and know how to use an ammeter, it would be beneficial to check the amp draw of the beater motor to determine if you are exceeding the overload or not. Ice cream is generally good at a temp between 16 and 20 degrees F. Temps vary with product and product brands. I hope this information helps, it is hard to determine exact problem without being there.
SOURCE: beater overload
if your mix level is low ice cream will freeze in cylinder which in turn will over amp the beater and cause it to trip. Check mix pump and make sure all orings are good.If mix isnt leaking out make sure it is pumping in.
SOURCE: I just need the operational manual for Taylor
here is your manual http://www.taylor-company.com/service/resources/op_man/0337op0.pdf
