If my measurements are correct it's a 16-48
Try this site
https://www.manualslib.com/
SOURCE: AM/FM radio on boat,
First thing i'd do here would be to investigate if the electromagnetic interference is coming in through the supply feed. I would bring another battery on board (Charged fully), one that isnt connected to the boats electrical system and see if the emi still afflicts reception. If it stops or reduces to a permissible level one can attack the problem with emi suppressors and filters. A good place to start would be the alternator, try suppressing the emi at source.
The second path the emi takes to pollute reception would be via air straight to the units antenna.
The solution sought here might not be a single remedy but a total of 3 or 4 tweaks, each leading to a percentage improvement. try shifting the antenna too, maybe shielding might contribute some.
Jango
SOURCE: Fisher & Paykel GW711 Washer
If you brought this machine new, then you should find a service manual under the display panel
You will need to remove the panel, Next to inlet valves you should find a maual in a plastic cover...
SOURCE: Need manual
you can download your manual from the following link -
http://safemanuals.com/user-guide-instructions-owner-manual/RAYMARINE/R10%20RADAR%20SYSTEMS-_E
post further comment if you have any problem related downloading the manuals....
Good Luck!!!
SOURCE: Can't find the year of used boat I bought on either tag.
Hi, the only reference I can find is where Richland started manufacturing for Sears in the 50's. This link for a forum could be usefull: http://www.pontoonforums.com/viewtopic.php?f=2&t=2545&view=next
Hope this helps
