k
kelsies banks Posted on Mar 26, 2017
How to reset my apple ipod touch - iPod Apple Audio Players & Recorders
5 Related Answers
Anonymous
  • 59 Answers
  • Posted on May 15, 2009
SOURCE: i can't open my yahoo messenger from my apple ipod touch
try to get a free app from the app store and install it the may solve ur problem
suresh chandra
  • 57 Answers
  • Posted on May 20, 2009
SOURCE: ipod touch can not boot.It show apple logo
Hope u have back-up...Do a reset..soft one ....
hope it helps...keep the hope:)
Anonymous
  • 24 Answers
  • Posted on Jul 29, 2009
SOURCE: ipod touch disabled
If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode.
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present.
Anonymous
  • 4 Answers
  • Posted on Sep 10, 2009
SOURCE: ipod touch freezes at the apple logo
mine did the same thing. plug it into the computer. when it's open in iTunes, set the iPod to manual. sometimes when it's automatic, it'll clear itself out/freeze up until you plug it in again. this worked for me. it could be a glich, or their way of getting us to go onto iTunes more often.
Cliff
  • 45 Answers
  • Posted on Feb 21, 2010
SOURCE: how can i reset my apple ipod classic?
This link to the apple support site will help you
http://support.apple.com/kb/HT1320
Forgot everything to my apple account for my ipod
Perform a straightforward reset procedure on your iPod Touch if you are experiencing issues like freezing, unresponsive apps, delays or other other problems. Carry out a reset if your iPod doesn't respond when you attempt to restart the unit. This type of reset will not erase any content from your iPod Touch.
Locate the "Sleep/Wake" button on the top of the iPod Touch. Press and hold down the "Sleep/Wake" button and the "Home" button simultaneously. Continue to hold both buttons for at least 10 seconds. Release the "Sleep/Wake" button and the "Home" button when the Apple logo appears on the screen, indicating the device has been reset.
tip
How to reset forgotten password Apple Ipod Touch.
Try a soft reset and hard reset your iPod Touch if it’s frozen or not responding.
Try a soft reset first:
1. Press and hold theSleep/Wake button on the top of the unit until a red slider appears
2. Drag the slider.
3. Press and hold theSleep/Wake button until the Apple logo appears.
If a soft reset doesn’t work, try a hard reset:
Press and hold both the Sleep/Wake button and the Home button for about ten seconds, until the Apple logo appears.
on Feb 11, 2010 • Apple iPod touch
2helpful
My ipod touch is locked up for 21738236 minutes does any one now how to help me???
Have you reset it? if not
To restart iPod touch, first turn iPod touch off by pressing and holding the Sleep/Wake button until a red slider appears. Slide your finger across the slider and iPod touch will turn off after a few moments.
Next, turn iPod touch on by pressing and holding the Sleep/Wake button until the Apple logo appears.
If its not responding do a hard reset.
To reset it, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds, until the Apple logo appears.
2helpful
My ipod touch wont work
If iPod touch won't turn on, or if the display freezes or doesn't respond
  • iPod touch may need charging. See "Charging the Battery" in the iPod touch Features Guide.
  • Press and hold the Home button for at least six seconds, until the application you were using quits.
  • If that doesn't work, turn off iPod touch and turn it on again. Press and hold the Sleep/Wake button on top of iPod touch for a few seconds until a red slider appears, and then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  • If that doesn't work, reset iPod touch. Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears.
If iPod touch continues to freeze or not respond after you reset it
  • Reset iPod touch settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media are left untouched.
  • If that doesn't work, erase all content on iPod touch. From the Home screen choose Settings > General > Reset > "Erase All Content and Settings." All your preferences are reset, and all your data and media are removed from iPod touch.
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
I want to reboot my ipod touch apple
Just re-boot or restore?
Reset is more about hard reset, for those familiar with terms associated with PDA, Palm or Windows Mobile. In other word, reset is simply a forced reboot
  • power is cut off from iPhone or iPod Touch to restart the device from fresh.
Restore will erase and wipe out completely all information and data that contained inside the device, including musics, songs, videos, contacts, photos, calendar information, call lists, maps, applications installed and any other data.
  • To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
http://www.mydigitallife.info/2007/10/04/how-to-reset-iphone-and-ipod-touch-hard-reset-or-reboot/
1helpful
2answers
Ipod touch 2nd gen, speaker played for 2 day,
go to the apple store or call apple. the should replace it for you for free.
How to reset my Itouch without connecting to a PC
window.google_render_ad();
Pin locked apple ipod 16gb
Apple Supportdocumented how to perform a reset. However, note that resetting theiPhone or iPod is not the same with restoring the iPhone or iPod.Restore will erase and wipe out completely all information and datathat contained inside the device, including musics, songs, videos,contacts, photos, calendar information, call lists, maps, applicationsinstalled and any other data. All iPhone or iPod Touchsettings are restored to their factory condition. Meanwhile, reset ismore about hard reset, for those familiar with terms associated withPDA, Palm or Windows Mobile. In other word, reset is simply a forcedreboot, where power is cut off from iPhone or iPod Touch to restart the device from fresh.
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Homebutton simultaneously at the same time for at least ten seconds, thenthe LCD display will clear and the Apple logo appears on the blackbackground. When Apple logo appears, reset is done.
-mydigitallife
2helpful
Ipod touch frozen on Itune connection
Per the first Google result for "reset ipod touch", http://www.mydigitallife.info/2007/10/04/how-to-reset-iphone-and-ipod-touch-hard-reset-or-reboot/ says:
"Press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done"
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
