Question about Rangemaster Kitchen Ranges
I have a rangemaster classic 90 dual fuel..we have changed the spark generator. Now it sparks on all burners but when the oven is lit the sparking continues on all burners, how do we stop this?
    Scholar:
    New Friend:
  • 69 Answers
Hello Stephany,
this cooker has an ignition system by pressing the knob of the item that you want to ignite.
As all sparkplugs work and only the oven is the source of the problem, i think that the contact behind the knob of the oven sticks
I have a rangemaster classic 90 dual fuel..we have - a40114-bxvwimtpanuivq3sgra5z31g-5-0.jpg
It looks like this one and is behind the facia, between the knob and the valve.
I hope this helps, Dik
Posted on Feb 17, 2018
SOURCE:
freetek
  • 5569 Answers
SOURCE: Electric spark for gas range burner is non stop
Turning any knob starts the spark via a switch behind each which should disengage when the (any) knob is turn further.
One of your switches is stuck.
I think you should be able to remove the range-top for access and find the offending switch.
It is probably gummy from a spill and is no longer in solid contact with the cam that operates it.
A solvent/lubricant such as WD-40 sprayed on the plunger of the switch once you can see it and operating the knob back and forth should free it up.
It might be wise to turn off the gas supply while tinkering with the range - blow your house away and the range won't matter. :-(
Posted on Jun 19, 2008
SOURCE: ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
Posted on Jul 22, 2008
  • 1214 Answers
SOURCE: Griddle burner wont spark
Make certain the burner and burner base are very clean by carefully washing in warm soapy water, using a plastic brush to scrub any residue off the surfaces. Also clean the spark ignition nub in this same way.
Posted on Jan 24, 2009
SOURCE: my rangemaster 110 ignition spark will not turn
Hi, I have the same problem did you find the solution?
Posted on Jun 16, 2010
heatman101
  • 43501 Answers
SOURCE: Premier 20" range with electronic ignition - the
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Sep 08, 2010
Clock and ingnition not working on a rangemaster dual fuel stove
  • Hello David,
    when the clock does not work, the (left hand) oven will not work too I suppose.
    Often when the clock does not work, it is only the timer that does not work. In that case, the timer can be bypassed. The oven still works then, but without the timer and the clock will also work as a clock.
    So no timer.
    When it is an older rangemaster, and the ignition does not work, then probably are some wires leaking. I that case the power for the spark does not come to the burner sparkplug.
    But when all plugs do not spark then there are 2 possibilities I think.
    1 the ignitor is gone
    2 the ignitor does not get power
    I hope this helps, I wish you a good weekend, Dik
Leisure Rangemaster 110 Electric Range Cooker How to bypass
Mar 05, 2017 | Rangemaster Kitchen Ranges
My rangemaster professional + 90 gas is when you turn on the oven and turn up the gas all the burners igniters start working can you please help .
Hello. Normally the ignitors WILL all start sparking--only the burner you've initiated will turn on. All the ignitors are wired together with a harness underneath the cooktop. This harness is connected to a spark module and when you choose whichever burner, it simply energizes the module. Only the burner with gas flowing will ignite. I hope this helps you!
Sep 03, 2015 | Rangemaster Kitchen Ranges
Spark generator will not stop sparking but no spark at electrode on burner in oven
Sorry to read about your problem, I hope this helps you out.
you have a stuck control switch
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Rangemaster Elan 90 (Dual Fuel) Dual Fuel...
Sparker doesn`t work on wok burner, i have replaced it but still doesnt work, it does spark if you place a screw driver from sparker across to the ring
sparker sounds like its ok but its sounds like it needs to be adjusted a little so it can ground out to cause the spark you need
Apr 08, 2010 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Don't know what electricity supply is required
Emmet in luton: what fuse does a rangemaster 90 duel fuel need?
Apr 10, 2009 | Rangemaster Classic 90 (Electric) Kitchen...
Gas oven operation
spark should stop when burner is lit.clean the probe with a light sandpaper and see if this corrects it.
Sep 24, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Kitchen Ranges Logo
66 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Thomas F. Schneider
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
