SOURCE: No Sound
It seems to be that the antenna is at fault. If you can take it apart, you should resolder the antenna.
SOURCE: setting up Jabra VBT2050 Bluetooth
I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
SOURCE: How to set FM Frequency on XM Radio Delpi SkyFi
is this a skyfi 1 2 or 3. if its a two or three if you go to the menu button and scroll down to fm frequencys and select that from the drop down menu. then scroll through the built in frequencies and determine which one comes in the clearest. if its a skyfi one then your gonna have to put in a wired fm modulator because the first one doesnt come with a wireless fm transmitter.
SOURCE: CD,AM, FM radio, How do I set the clock.....no
try to download the manual from herehttp://www.devicemanuals.com/guide/Automobile/GMC/GMC-Sierra-Owner's-Manual-2004-==TVRBNU5UUTQ=.html
SOURCE: Dual XDMR7710 player wont save settings
Cut the red and yellow wires and cross them to the opposites and connect again and this will save your cd players memory
