Question about FoodSaver Kitchen Appliances - Others
Foodsaver vac 800 How to change the gaskets - FoodSaver Kitchen Appliances - Others
Foodsaver vac 1050
Perhaps the bags you are using are not suitable. If they are too thin it will not vacuum air out.
Apr 30, 2018 | FoodSaver Vac 800 Vacuum-Sealing Kit,...
No suction to seal bag
is a hose unplugged? Unplug the devise and see if you can find anything that looks like it's not connected OR it has a hole in the hose.
Sep 07, 2012 | FoodSaver Vac 800 Vacuum-Sealing Kit,...
Trying to find a gasket for ......food saver vac 820
Replacement parts for the Tilia Foodsaver products can normaly be found here:
http://www.foodsaver.com/parts.aspx?search=420
However I am having trouble with your model number. Are you sure it is correct?
Suggest you inquire with the company as to which listed model would be compatible with your model . You may contact them over the web here:
https://secure.foodsaver.com/contactus.aspx
Aug 14, 2011 | Tilia FoodSaver VAC420
My sealing gasket is broken and it will not seal my food anymore. model 1050
Replacement parts for your product may be ordered online here:
http://www.foodsaver.com/Category.aspx?id=r
If you are unsure which gasket to order contact FoodSaver via their website:
https://secure.foodsaver.com/ContactUs.aspx
Feb 08, 2011 | Tilia FoodSaver V2240
My foodsaver Vac 420 Vacuum Sealer won't heat and seal the bags.
This is likely happening because the unit cannot detect that a vacuum has formed, and because of this, the unit will not seal the bags, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Mar 29, 2010 | Tilia FoodSaver VAC420
My foodsaver v2490 will not vaccum the air out the bags...it is almost new with very little use
the problems with vac is allmost allways the gasket or the tubing in the unit there is a few fittings that get britlle over time and the heat in the unit and the china parts dont help i have got a bunch of these broken units on ebay and fix with drip irr fittings
Oct 21, 2009 | Tilia FoodSaver VAC420
Kitchen Appliances - Others Logo
126 people viewed this question
Top FoodSaver Kitchen Appliances - Others Experts
Andrew Taylor
Andrew Taylor
Jim Busse
Jim Busse
Level 1 Expert
lucboisseau5
Level 1 Expert
Are you a FoodSaver Kitchen Appliances - Other Expert? Answer questions, earn points and help others
