Tried swip but get a red line that says E:error opening '/data/local/nhmsystem/Kali-armhf/dev/ram1' next line says E:error: not a directory
SOURCE: recognized - but no mount
Don't know about the MAC part, but an I/O error implies that the either the source file cannot be read or the destination drive will not write. This is usually an indicator of a bad HDD. To check, I would attempt to connect the external drive to another computer. If it still gives the same indication, contact the drive manufacturer about data recovery recommendations
SOURCE: All data has "disappeared" from my 300G usb 2.0 drive.
you can use a software called g parted , you have to make a dos bootable , and then mount volumes to make the drive ready.
gparted will help you... try the trial version .if you dont susceed let me know.
SOURCE: Rhem 2 System requirements
When I checked the manual--the system requirements said to make sure i had QUICK TIME 6 FOR WINDOWS--installed. So I am going to try this----- they said to go to
www.apple.com/quicktime/
hope it works and gets rid of the big red X
SOURCE: IdeaPad S10e Netbook: CANT OPEN LENOVO ONE KEY RECOVERY UPON START...
Make sure you did it correctly. Computer should be OFF when doing the one key recovery. Turn off the computer then press the small button right beside the power button. Your computer should automatically turned on and you will go straight to one key recovery software. If this will not happen, then the one key recovery is destroyed. We need to re-image your Harddrive to have that one key recovery software back to you computer. You may call Lenovo technical support department for further assistance on how you are going to send your laptop to our depot department.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
I'm sorry to hear you're having difficulty with your DC24. If you haven't been able to reset the brushbar using the reset switch on the cleaner head, I'd encourage you to get in touch with us directly so we can provide further assistance. You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US) - please have the machine to hand when you call so we can run through some troubleshooting over the phone with you.
We'll look forward to helping you resolve this.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
