Question about Ranger Radio Communications
I need a user manual for Ranger RCI-2980 WX - Ranger Radio Communications
6ya staff
SOURCE:
Anonymous
SOURCE: radio has no modulation
probably a final is out.
Posted on Feb 03, 2009
Anonymous
  • 39 Answers
SOURCE: need wireing diagram for a rci 2980 to tug8 mic
Here is what I have: If the Tug 8 is a 4 wire cable,1/shield 2/white 3/red 4/black 5/N/C 6/N/C
If the TUG 8 is 6 wire cable,1/shield & blue 2/white 3/red 4/black 5/N/C 6/N/C .The reason I gave two diagrams is I can never remember if the 8 or the 9 is 4 wire cable.Also if your radio keys up when you plug mic in reverse the black and red.Good Luck and take care!
Posted on Feb 25, 2009
SD Tech
SD Tech
  • 14553 Answers
SOURCE: need user manual for ranger rci-6900f turbo
Here is a link that goes to RCI for the complete manual for this model----let me know if you have questions.
If this helped you rate this solution as I do this here for free.
SD TECH
http://www.rangerusa.com/pdf/man6900f.pdf
Posted on Jan 03, 2010
kb8dns
Rod Wallberg
  • 494 Answers
SOURCE: RCI-2980 NO MODULATION
Microphones are the most handled object with a CB radio and this is where it is most likely to find the problems. Basically a Galaxy radio in a base station box, and 3 out of ten develop problems, mostly power supply problems.
I would suspect the mic first. Best way is to use a different mic and see if the problem goes away. Next try the radio on an external DC supply or battery. Let me know what happens from there..... poikaa@yahoo.com
Posted on Feb 20, 2010
Ernest Taylor
  • 67 Answers
SOURCE: ranger rci 2970n2 radio need
AMC:
Mode to AM
Set generator for 30mV RMS, 1KHz sinewave.
With Mic gain at maximum VR14 Adjust for 100% modulation. Use modulation meter or oscilloscope with RF sampler.
Posted on Feb 27, 2011
Manual 2995 RCI Needed.I would like to order one
  • Hope this helps.
Regards, Tony
Oct 14, 2011 | Ranger RCI-2995DX Base Scanner
Need user manual for a Ranger TR 127FS
Service manual is on the CBTricks.Com website. Look in the index for TR-127GK. This the same radio under the covers. This should suffice as an owners manual also.
....Don at NTCB, Inc.
Jun 22, 2011 | Ranger Communications RCI-6900F-25 CB...
Bought a used RCI-2995DX CB and no owners manual how can I get one
Ranger Parts and Service is in California. (760) 440-0125
Dec 14, 2010 | Ranger RCI-2995DX Base Scanner
Need operating instructions for RCI-6300F150
You can download and print the operating manual for your 10-meter transceiver here:
http://www.cbtricks.com/radios/rci/rci_6300_f25/graphics/rci_6300_f25_f150_om.pdf
In case you need it, you can also download and print the service manual here:
http://www.cbtricks.com/radios/rci/rci_6300_f25/graphics/rci_6300_f25_f150_sm.pdf
Bill B.
Oct 25, 2010 | Ranger RCI-6300F-150 Base Scanner
Need user manual for ranger rci-6900f turbo
SD TECH
Dec 17, 2009 | Ranger Communications RCI-6900F-25 CB...
I need a manual to base station CB Ranger rci-2990. Can you tell me where to download or purchase this manual. Thanks
http://www.rangerusa.com/websupport.html
http://www.worldwidedx.com/cb-band-cb-radios/18036-manual-rci-2990-a.html
you may find some help with these sites
Sep 24, 2009 | Radio Communications
The s-meter goes down scale when I am modulating. What causes this? THIS IS ON A RCI 2980 RADIO
the reason i saked is that if you turn the power all the way up it tends to reverse modulate. this happens because the power is using all the transmit voltage for the final and the modulation circuit is trying to use as much as it can so the radio is most likly out of alignment and needs to be realigned. its not that hard if you have the service manual and the correct equipment. i have a factory authorized shop and we do alot of realignments due to the cb shops tweaking the 10 meter radios.
Mar 12, 2009 | Ranger RCI-6900F-150 CB Radio
Radio has no modulation
Feb 01, 2009 | Radio Communications
Radio Communications Logo
737 people viewed this question
Top Ranger Radio Communications Experts
Mike Charette
normis101
Robert McClure
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
