SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
SOURCE: error code 43 on F& P washing machine
Carefully remove control console, then control board. Take note of which connector came from which terminal! Balance sensor is located under control board. Remove with care. Check that little button (size of pen top or pencil lead) is moving in & out freely. It is spring loaded. If it sticks, replace it. Hope this helps.
SOURCE: LG model WM2277HW front load washing machine,
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
1) in my experience, sometimes this proves to be intermitent, and upon unplugging and waiting for 5 minutes does not seem to resurface again...
2)Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount.
this could prove to be very challenging to somebody who does not know what they are working with, i suggest if the problem is not intermitent, call a tech.. hope this helps.
SOURCE: error code 131
http://www.docstoc.com/docs/25379715/Fisher-_-Paykel-Washer-Diagnostic-Fault-Codes/
A;; fault codes above.
SOURCE: Defy - 13KG Laundromaid 1300
Here's a solution I've gotten from one of the experts..
"Clean the drain motor lint tray/filter. So many 'faults' are
caused by blocked filters. The motor is unable to drain all of the water
in the allotted time.
If you are unsure where the filter is, it is normally behind the front
lower (kick) panel (or in some machines at the rear in an awkward
position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the
drain motor and ensure it is not jammed by a foreign object such as a
needle or a toothpick. It should be able to be turned by hand/finger-
the power IS OFF!
At this point it is also possible to test if the motor works. No clothes
or water in the machine, select a spin cycle and put the power back on.
You should be able to see the motor turning at some point, possibly
straight away. If it doesn't work then the motor is malfunctioning!"
Hope this helps.. Good luck! :)
