SOURCE: No Assisted Speech Recognition icons
Technically, ASR is not officially supported on the 720, so their is no guarantees. But, first make sure you have the latest application installed via HOME, 'Update my GO'.
Then, open Notepad and type the number 1 ("1"), without quotes, in the editor. Save this file as 'SUPPORT_ASR.cab' (again, without quotes). It's important that you change the extension of the file from .txt to .cab. Then copy this file into the 'ASR' folder on your TomTom device. Allow your TomTom to boot up and try it again. Also, the icons will be greyed out if you haven't selected a country/state.
SOURCE: Speech Recognition in Vista
just reinstall the whole application
and install visual basic
start the application
if it give error start it with visual basic
SOURCE: Vista Speech Recognition will not start.
Dont worry.This issue can be resolved.I did research on this.Create another administrator account and see whether it works there.I dont have an answer why it is not in this account as i couldnt find one
SOURCE: Hi I installed the Rosetta
if you changed the default directory for your language installation, it is likely that UACin Win7/Vista is preventing the installation hence missing files. Either run as admin and add language again or reinstall and let it install in its default location
To switch languages or
keyboards from the taskbar
Notes
keyboards from the Language bar
Notes
To install speech recognition by using Add or Remove
Programs, follow the given steps:
Click Start, and then click Run.
Type control appwiz.cpl add new hardware in the Open box,
and then press ENTER. The Add or Remove Programs window is displayed.
Click Microsoft Office, and then click Change.
Click Add or Remove Features, and then click Next.
Under Features to install, double-click Office Shared
Features.
Double-click Alternative User Input, click Speech, click the
down arrow, and then click Run from My Computer.
Click Update. Speech recognition is now
available in all Office programs and other programs for which it is enabled,
such as Internet Explorer.
