Question about Kirby G6 Bagged Upright Vacuum
Looking for a manual for a kirby Heritage 11 modle 2HD
Looking for an manual for a kirby 11 Heritage vaccum cleaner with carpet shampoo attachments, modle 2HD
It is at least 30 years old.
Thank you,
Linda
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 71 Answers
Hello
I did a search and found a very useful web site for owners of the same vaccum as yours im sure you will be able to get parts and possibly a manual, hope it helps
http://kirby-owners-club-shop.com/
Posted on Jul 23, 2009
SOURCE:
Tip
How To Attach The Carpet Shampooer To A Kirby Generation 5 (G5) Vacuum Cleaner
The Kirby carpet shampooer is an attachment that is used with the Kirby upright vacuum cleaners. It converts the Kirby from being used as a dry pickup vacuum, into a carpet shampooer and extractor. Unlike other carpet shampooers and carpet extractors, the Kirby shampoo system does not saturate the carpet with a lot of water when cleaning. Kirby shampoo systems use a special dry foam formula that gently cleans the carpet without saturation.
Installation
The link below is to an excellent, easy to follow and understand video that will explain step by step how to convert the Kirby Generation 5 (G5) from a vacuum cleaner into a carpet shampooer. Please note that the vacuum in the video is actually a newer Sentria model, however the repair procedure is identical on the G5 as it is on the Sentria.
Video Demonstration of Converting Kirby Generation 5 From Vacuum Into Carpet Shampooer:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
If you have any questions about the procedure of converting the Kirby G5 into a carpet cleaner, please feel free to request clarfication on this video right here on the Tip page. I hope that this video was helpful. If you did find the video helpful, please kindly rate this Tip as helpful by clicking on the Thumbs Up Icon in the lower right hand corner of the page.
Thank you very much for watching,
Chris J.
on Mar 21, 2010 | Kirby G5 Bagged Upright Vacuum
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
What solution do I use to shampoo my carpet with the Kirby Heritage II vacuum
Genuine Kirby Shampoo is recommended. Refer to http://www.kirby.com/ to locate the website for your country.
Or call
United States and Canada: 1-800-494-8586
United Kingdom: 0800-328-1247
Europe: 00-800-5472-9272
South Africa: 0800-203-222
May 24, 2010 | Kirby Heritage II Vacuum
Old Kirby Heritage 2 (Model 2Hd ) won't power on
the power light is a 2 stepswitch make sure when u put yhe power head back on it is locking all the way back if so and not working the switch may have failed
Jul 10, 2009 | Kirby Vacuums
About kirby carpet extracters
The heritage 2 pulls 5.5 amps or 660 watts in hose mode and 4.5 amps or 540 watts in carpet mode.
Volts to Watts
The conversion of Volts to Watts is governed by the equation Watts = Amps x Volts
Mar 24, 2009 | Kirby Heritage II Vacuum
How to use shampooer on Kirby Sentria Upright
Kirby shampoo manual with plenty of pictures HERE
Good Luck
Rocky
Mar 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do I attach and use the shampooing attachment so I can clean my couch?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11557&thid=579274
How do I attach and use the shampooing attachment...
Posted by rottylvr on May 08, 2008
I have a Kirby Vacuum and Carpet Cleaner that I know how to use, all except the attachment that I am not sure about. I am not sure if it is a vacuuming attachment or can I attach it and use it to clean my couch, I do not have the user guide for my vacuum as I got it from my son's ex girlfriend in lieu of money she owed me. It looks like it should be used for shampooing things like stairs and furniture, but for the life of me I cannot figure it out! Can you please help me? Tell me how to attach it if it is supposed to be used to clean stairs and furniture or tell me where I can find the user guide to look at and see how to use it......Oh by the way I have a 160 pound rottweiler that tries to live on my furniture and my couch is in desperate need of cleaning, this is my only day off and I have spent all day cleaning carpets due to my dog and would love to clean my couch before returning to work and putting my dog in the back yard now that it is warm enough for him to be outside all day.
Thanks,
Desperate to reclaim her couch
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. My suggestion is that you contact the Kirby Co in Cleveland listed below and they will instruct you either to down load a owner’s manual or they will mail one out to you, there might be a local Kirby dealer in your area that might have a manual as well. Also, there is a separate shampoo head that will be in the owner’s manual, you remove the vacuum head and bag assm and attach the shampoo head, make sure you use genuine Kirby shampoo for the carpet. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
I have lost My Kirby G5 Manual
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11561&thid=539967
Posted by Marie1231 on Apr 23, 2008
I need to know how to use the attachments that came with the Kirby. I know how to use the shampoo/vacuum, but not the other attachments or the upholstery cleaner. Does anyone have any idea?
1st, you need to un-hook the lever @ the top of the Kirby head, dial off the belt from the Kirby Vacuum Head using the Kirby emblem in the front of the vacuum, that also serves as a hook/spoon to dial the belt off the fan pulley. Once you have removed the vacuum head you now hook up the attachment hose to use the attachments by locking the attachment hose to the top lever. All regular Kirby attachment will fix on the attachment hose end including the spin brush if you have one with your Kirby --- using the Kirby Shampoo spray the soiled area and use the spin brush to agitate the carpet and or upholstery, try not to use to much water. If you have a Kirby shampooer – use the recovery tank on the exhaust port of the Kirby (this means that the cloth/paper bag needs to come off and install the clear recovery tank. Please refer to the Kirby owners manual for any type of trouble shooting that you might need – or please feel free to contact your local vacuum dealer in the yellow pages or contact your Kirby factory manufacturer listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
583 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
