Replace the black image unit as a whole you do not replace the units as individual parts. Where did you get the drum from? or the PC charger as they come as one and you don't replace the developer as it is located inside the unit!!!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Printing on half page only
you need to clean laser but first try to change drum and toner
elvis
SOURCE: Bizhub C450
sounds like the wrong image unit. Oce and ollivetti have the same machine and take the same image unit but with a different chip. Make sure it is a genuine konica minolta image unit. If need be try putting the chip from the old unit on the new one and see if lays down the colour
SOURCE: How do I reset the Unit Life after replacing black imaging unit?
Just reset the chip. More details you can find here: http://www.chipreset.eu
SOURCE: have a oki c9800 ...gives error 923
923: Error - Black Image Drum Lock Error
The K ID unit is not operating
properly.
Check to confirm that Image Drum is seated properly.
Check to confirm that the K ID
unit is in position.
Replace the K ID unit.
Replace the K ID motor.
SOURCE: how I can reset counter imaging unit bizhub c450?
u cant reset those , u have to change the counter chips .These are available in market
