SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
SOURCE: TUMBLE DRYER DOES NOT GET HOT
Hi, - The first thing to do is UNPLUG THE DRYER! Then remove the heater cover situated on the back panel. It is the curvey shaped panel.
Remove all the screws and the panel may be slightly stuck - just prise it off.
Next - there are 2 small screws holding the heater and thermostats assy onto the back panel. - Remove these to free the assy from the back panel. Be careful not to touch the elements as they break easily.
The problem is probably the Thermostats.
The one on the left is the Overheat Thermostat - You will notice a small hole in the centre of the thermostat. Take a Pin and push it firmly into the hole and you may hear the Stat "click". That has re-set the stat.
Re-assemble the Dryer being careful with the elements.
Now - Why has it tripped? If it has overheated it is because of one or all of the following.
1. The Condenser unit is getting blocked - Remove and clean under running water like a hosepipe or tap.
2. The door filter is not being cleaned
3. Sometimes opening the door to check if the clothes are dry and then not allowing the dryer to cool down can cause the problem. Always allow it to go through the cool down process.
Hope this helps. The Heater and the Thermostats are available as Spares - Terry
SOURCE: Tumble Dryer-empty water light won't go off
remove panel on rhs looking from back and you will see a chamber with a microswitch on top. either micrswitch is stuck, pump faulty or a lint blockage
SOURCE: I don't have any heat from my hotpoint aquarius ctd40G tumble dry
Remove the rear cover and you will see the element and stats, you will need a meter to test them.
Pull one wire off each thermostat and with a meter that beeps, test across each thermostat, if they are o/k, then the meter will beep,
if no beep then no good.
Replace all heater stats, even if only one has gone
If the stats are o/k then you will have to check the heater, this is more involved as it entails removing the top cover and left side panel looking at the dryer from the rear.
Unplug the heater lead, and again test with meter,if element o/k, then prob is timer or main pcb could be faulty, it really does get quite involved.
There is also a thermistor at the front of the dryer, that is part of the heating circuit.
Plz rate my solution.
Thnks.
SOURCE: hotpoint tumble dryer is making
This sound is caused by the drum tilting towards the rear panel just above the heating element housing and is due to the drum spindle wearing through the bearing. (Which can lead to it shearing off) after it`s cut it `s way into the bearing support bracket. A new rear bearing kit is needed. it will come with a foam support which is stuck on to the inside of the back panel as the drum rests against this when turning. the foam support on your dryer may have perished or gone flat due to the heat from the element and that is why your hearing the scaping sound. new foam ring from the bearng kit will cure the scraping.
My Hotpoint Aquarius TCD32 0771200901
Tumble dryer stopped working, first a filter
care light, so cleaned the filter and now the light comes on but nothing
happens. Any ideas? Thanks
