SOURCE: bauknecht washing machine fault
Had the same problem myslef yesterday. Have rung whirlpool this morning and they advise that the code F7 refers to a short circuit.
SOURCE: Fault code 130
rotary position sensor fault. underneath the machine. Unbolt plastic cover with 16mm socket all of the plastic will come off. Undo four 10mm bolts around shaft. Pull off the big round thingy with cooper wire on it carefully. The purple wire is connected to the sensor which looks like a computer card and fits between the copper things ,pull up the sensor carefully and unpug the connection clean off the blue stuff on contacts,use electrical spray cleaner. Put back together in reverse.
Comments: Aug 03, 2009 - if it still doesnt work reset the machine by turning it off at the wall and waiting 2mins and start again. If that doesnt work the sensor may need replacing.
SOURCE: hi, on my WAE8987 Washing machine, the fault code
Bauknecht are built by Whirlpool.
F7 on Whirlpool means flow meter failure.
Check water inlet, check the pressure switch, and check the sump filter at the bottom of the dishwasher.
To reset try turning on the power and holding the start button and the + and - buttons at the same time.
SOURCE: My fisher and paykel washing machine keeps flashing a fault code
needs a new Rps sensor , 130 is a fualty Rotor postion Sensor
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
