Request file Help How to download resident evil 4 layout bin file download file to ... for layout.bin file like "please insert disk 1 that contain the file layout.bin"but I ...
See how to recover the files deleted from Windows Recycle Bin or with Shift + Del. The Windows operating system places all deleted files into a special folder named Recycle Bin. If an important file was deleted by mistake, you can always find it there. However, the size of Recycle Bin is limited, and the system empties it as it becomes full. What is more, the files, deleted with Shift + Del or larger than the size allocated for Recycle Bin, are never sent to Recycle Bin.
Read how to recover files deleted from Windows Recycle Bin or with Shift + Del - https://hetmanrecovery.com/file_uneraser/hetman_uneraser.htm
If you faced such a problem, just follow our advice:
1. Make sure your file is not in the Recycle Bin and you don't have its backup copy left. Your Windows may have enabled some backup functions, such as file history, restore points, system image creation etc.
2. Use the link in the description of this video to download and install Hetman Uneraser. Remember that you have to start data recovery as soon as possible, because the work of the operating system is connected with the permanent process of creating new files on the system disk.
Now let us see in detail how you can use Hetman Uneraser to recover files after Windows Recycle Bin is emptied or after such files were deleted with Shift + Del.
To do it, let's reconstruct a situation when important files can be lost.
• There is a folder containing various files on disk D
• Delete it by pressing the key combination Shift + Del
• as you can see the folder containing files is deleted, and these files cannot be seen on the disk or in Recycle Bin
So how can you use Hetman Uneraser to recover files after Windows Recycle Bin is emptied or after such files were deleted with Shift + Del?
• Click on "Wizard"
• The File Recovery wizard opens, "Next"
• Select the drive where the accidentaly deleted files were stored. In my case, it is disk D, "Next"
• Leave the default checkbox "Normal scan," "Next".
• In this window you can only specify the necessary file types to speed up the process of analysis and data recovery. For example, I will check "Selected file types" - in my case they are archives, audio, video files and images. When you unfold the list, you can specify even more which file types should be searched. I will leave default settings and click "Next."
• In additional options, you can specify the date when the files were created, opened or modified, and the file size to make the search more exact. You can also choose "Deleted files only" and other options. I will leave the settings as they are and will check "Deleted files only" because in my case I deleted the files - which means they were not lost, for example, as a result of a hard disk failure. Next.
• Wait for the process to be complete.
• The files have been found. You can uncheck the files you don't need and leave only those which are necessary, "Next".
• Here, select "Save to hard disk" and specify the path where the files will be recovered to. Click "Recovery" and wait - it can take some time.
• Ready.
As you have just seen, the program did the job easily and quickly, and it took me almost no effort, thanks to the user-friendly interface and an easy-to-use recovery wizard.
The AWARD BIOS has a similar procedure to AMI. To recover an AWARD BIOS you will need to create a bootable floppy diskette and add the desired BIOS file (we recommend using the most recent). Award BIOS's generally are in .BIN format, where as AMI was .ROM format. You will also add an AWARD flash utility (usually awdflash.exe) and an AUTOEXEC.BAT file.
The AWARD BIOS does not automatically restore the BIOS information to the 'system block' like the AMI BIOS does. You will need to add the commands necessary to flash the BIOS in the AUTOEXEC.BAT file. The system will run the AUTOEXEC.BAT file, which contains the flash instructions.
Note: 12345678.BIN represents the name of your BIOS.
Step by Step:
1. Create a bootable floppy diskette or bootable dos cd /usb drive
2. Copy the BIOS file and flash utility to the disk
3. Create an text file with any standard text editor and add the following lines
@ECHO OFF
awdflash 12345678.BIN /py/sn/f/cc/r
Exchange the awdflash with the name of whatever flash utility you are using, and replace the 12345678.BIN with the name of the BIOS file you are using. The parameters are explained here:
py = program yes sn = save no f = flash cc = clear cmos r = reboot
