All you have to do, depending on your connection. If you are wireless through your Gateway or modem, the wireless encription key is physically on the modem itself. If you use a router to connect wirelessly, you will need that WEP key, You can also go to your wireless setting or view your available network, the go to properties. If you have connect wirelessly before, you should have the passcode written down Then when you find it, turn on In settings, on your I touch, turn on wifi, then it will ask for the code. Put the number in.
