Question about Element Electronics Televison & Video
How do I reset the remote to my element electronics ELCHW261 tv. It won't work anything on my television
SOURCE:
SOURCE: Element Electronics FLX2211B 22 in. LCD TV will reset every time
I have run into the same problem with a different model (32 inch from Circuit City). You may have found that there is almost no support from the co or web. I do not have an official solution but have some work arounds that have done the job for me.
WA#1 = after a channel scan tune to a HD/digital channel before you turn the set off. You need to do this each time for several times, because the set when turned on to a regular cable or analog station will default to skip all channels. After several times the set should remember your channels.
WA#2 = after a channel scan, go to the skip channel section of the menu, and if your remote has the colored buttons on the bottom scroll through the channels using the red and green (up and down on this menu) buttons. This apparently helps the set remember not to skip your scanned channels.
These are not glamorous solutions but appear to trick the TV into not re-setting the skip function for the channels.
Best of luck.
Posted on Jun 03, 2009
SOURCE: Element flx-3210 lcd tv
I have the same problem connecting from my computer
Posted on Jan 19, 2010
SOURCE: I need a Remote foe a 26" Element TV
I have a brand new one....give me an offer on it
Dreamster66@yahoo.com
Posted on Feb 13, 2010
WhiteFox4
  • 641 Answers
SOURCE: Electronic eye seems tohave quit working.
So if your remote is working but the tv sensor is not, you could possibly unplug it and take off the casing and resolder the connection to the board :) I would examine the sensors connections to the video board and also around for any capacitors or any components that can be tested with a multimeter on Ohms. I'm no expert and have fixed flybacks, transistors, capacitors, opticals... sometimes it just needs resolder. sometimes the copper tracing gets fried off the board and shorted out because of dust. this happened inside my computer on two USB ports. TVs are also dusty especially around the externals.
Posted on Mar 14, 2010
raycalo
  • 358 Answers
SOURCE: dish remote
cathyw43
I have provided instructions on how to program your DISH remote to your TV. I have also provided a link with the codes for TV manufacturers. I hope this helps.
Program remote, step 6:
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Ray Calo
DISH Network
Posted on Feb 03, 2011
Modl#elech321 hdtv hdml dolby digital tv
Could be failure of the internal power supply
Mar 14, 2013 | Element Electronics ELCHW261 26 in. TV
Turn off widescreen on element elchw261 tv
Select menu in remote control, select format, change ratio size to fit your screen. If you do not know the correct format, you may have to try all the options.
Jul 04, 2012 | Element Electronics ELCHW261 26 in. TV
Where do i get a replacement lcd dcreen for a element 26 in. ELCHW261
Nowhere. If the lcd panel is busted it's cheaper to buy a new tv than fix to one you have.
Feb 03, 2010 | Element Electronics ELCHW261 26 in. TV
ELCHW261 in a bath room?
Yes,room must have well venturlation,not go beyon 90 degree more than hour.Well damage your electronics componnents,or well shorten their life 40%.LCD Screen have no effect on heat or cold only the electronics componnents that the problems.
Jan 11, 2010 | Element Electronics ELCHW261 26 in. TV
Dec 29, 2009 | Element Electronics ELCHW261 26 in. TV
Televison & Video Logo
41 people viewed this question
Top Element Electronics Televison & Video Experts
Steve Allison
Steve Allison
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
