Question about DeLonghi Coffee Makers & Espresso Machines
DeLonghi Rialto EAM-4500. When I turn it on, it makes loud noises and give me the following message:Ground too fine adjust grinder and insert water spout
    Habit-Forming:
    New Friend:
  • 17 Answers
Step: 1 Switch off your coffee maker. Remove the first brewer unit. Wash it thoroughly under running water.
Step 2: clean the coffee grinder using vaccum cleaner.
Step 3: switch on the Machine !!! Make Coffee
(Note: if you hear loud noises during coffee preparation then please use food graded grease to fix it)
Posted on Mar 20, 2017
6ya staff
SOURCE:
Empty circuit fill circuit insert water spout press ok
when inserted the water spout if the water is delivered,that means you have an issue with the flow meter and you have to tack it to maintain,
how ever if the message (fill circuit ) turned off after the posses of filling the circuit and when you are trying to brow coffee the message shows, that means the grinder is too fine adjust it and try ones more
Apr 12, 2015 | DeLonghi PrimaDonna S Deluxe Super...
I have a Delonghi EAM 3400 espresso machine. The problem I am having is that when I select an espresso very little comes out and it just drips instead of a full flow. It is also taking 4 minutes to brew...
It is likely that the coffee is ground too finely so if you turn the adjustment knob one click clockwise towards 7, while the coffee mill is working. Try clicking one click at the time until you are satisfied. Hope this works for you, Kolbrun
Nov 02, 2013 | DeLonghi EAM3400 Espresso Machine
On my Manifica which is about 5 years old I get the message that the ground is too fine and to adjust it when I am trying to froth the milk. I have cleaned it, adjusted it , taken all the beans out and it...
Hi
A grind that is too fine will result in your espresso being too bitter. Rinse between shots because the infuser clogs easily with black espresso muck. Not rinsing will cause the machine to shut down with a message that the "grind is too fine".
Try removing the beans from the hopper and use a vacuum to CLEAR/REMOVE any grounds and then adjust the grinder 4 clicks clockwise. Try turning the grinding regulator 1 click clockwise and see if that works.If not try inserting the water spout press the ok button and then run water a few seconds.
If you remove the water tank too early while it is making coffee it will display that message as well.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 03, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Delonghi Magnifica 3500.. error message says "grind too fine, adjust grinder, insert water spout, press ok" message never goes away. I called the Customer service.. she said try again.. to...
Try removing the beans from the hopper and use a vacuum to CLEAR/REMOVE any grounds and then adjust the grinder 4 clicks clockwise. If this works Re-adjust grinder to where you get nice crema.
You can try using all ready ground coffee by following the instructions in your manual (if you don't have a manual let me know) to test it.
Jan 12, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi rialto eam4500: Lost Hot Water Spout. Where to get one?
I had the same problem!! I was able to find one on Amazon:
http://www.amazon.com/DeLonghi-5532124900-HOT-WATER-SPOUT/dp/B002EKFX06
It works on 4500 as well as a couple of other models :)
Jul 25, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Delonghi rialto. i need a manuel and video
I'm not sure if there is a specific model number on yours. But here is a link to a DeLonghi Rialto 4500. http://www.starbucksstore.com/images/products/pdf/4_Rialto_Espresso_Machine.pdf
Feb 27, 2010 | DeLonghi Coffee Makers & Espresso Machines
Had the Rialto 4500 for over a year. All of a sudden the milk is not coming out properly, mostly just steam. I've cleaned the tube and container top many times ! What else can it be ?
Me too! They ordered me a new milk pitcher from Italy. Didn't work. They told me to run it through some tests using water in pitcher. Didn't work. They then told me to send it in to a Delonghi repair shop. They just told me that it was all "clogged up" and also needed a new generator. The tow are linked together. We descaled fairly regularly. Total tab: $380! OUch! Have not told them to go ahead. seaching for cheaper solutions. Let me know if you hear of any. wosbrink@me.com.
Will Houston TX
Oct 23, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Need descaling instructions for EAM 4500 auto espresso machine
use 1/4 cup of vinegar and fill pot with cold water, run through machine
Aug 01, 2009 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
368 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Pierre Laplante
MikePurcell
Level 1 Expert
Marvin
Marvin
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
