Do you mean the network lock? To unlock, I suggest you can approach Theunlockarena.com and specify the country,locked network of Nokia E72 .Based on the availability you can get the permanent unlock service along with free instructions.
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
SOURCE: SIR, I AM USING NOKIA 1600 MY PHONE KEYPAD
Try following steps to get your cell unlocked with out even putting password after you unlock it reser your phone:
Your cell is unlocked.
SOURCE: Dear Sir, Thanks a lot in
Hi, If
your phone freezes, hangs up unexpectedly, vibrates continuously ,touch screen
wont respond or in other similar ways doesn't perform as it should, this can
often be solved by performing a software update. Software may perform
incorrectly for many reasons without there being a fault in the phone. Some
problems may be fixed by re-updating your current software, while others may
require installing a new software version. To
keep your phone performing at its best, it's a good idea to perform a software
update regularly. You might not always notice what an update has done, but it
can prevent future problems. To
update or reinstall the software please go to nearest authorized service centre
of your mobile make and they will update or reinstall the software as required. Note:
Reinstalling the software will delete all the content in your phone like
contacts, calendar entry etc. If
still the problem persist please change the LCD screen.It will work fine. Thank
You
SOURCE: hye sir, sir i have nokia
hi
just reset your settings
[ Go to settings -> Security Settings -> Reset setting -> enter your security code The default is 0000 ]
before resetting make sure backup your data
after resetting the phone get the internet settings from your service provider then try again
if problem not solved mail me [email protected]
SOURCE: Dear Sir, Accidently, I installed the
Try to remove your memory card first and turn your phone on. If the problem still occurs, press the key * + 3 + Green Button together and hold that then Press the power button. This will reformat your phone and all data on the hpone memory will be deleted. Make sure you have enough battery charge to complete the procedure. Good Luck!
