to adjust the size of your wrist...eat chocolate! most watches with linked wristbands require the links removing.(small pins to b e pushed out) the type with the chain links usually have a clamp to release to slide the clasp up the band. the instructions should be with the watch manual. or ask a jeweler to help.
please post pictures if need more help so i can see the design
I've had to get extra links before, especially for ladies SS and gold bands. Sometimes a local dealer will have spares that will fit your watch. But, the best source I've found is Ebay. Let me know if you have the stock band or something else. I'll try to help you locate some extra links, or another replacement band at a modest cost. Thanks, Bill
Do you stil have the manual/instructions? I would contact any support number that is listed as GUCCI is the only place to get original links. Most watch companies will allow extra links with watch purchase. Contact them via your waranty/manual.
Best regards.
Hi Go to www.skagen.com top r/h search box - input your model number click on go,
On the new page at bottom/left, click on customer service.
On new page left side click on instructions.
On new page you will find instuctions on how to shorten/lengthen bracelet.
good morning ! you need a puncher pin and anvil to remove the pin on your watch band punch or push the pin use the puncher pin according to the arrow sign,full the pin to remove,and fush to fix again,do it carefully,thank you ! god bless .
I just recieved a Moldavo Men's Junior Sport (Model # 0605105 with certificate of authenticity) as an award -- but the instructions didn't bother explaining how to put the watch on!
I just did this for my wife's new Kenneth Cole wrist watch rather easily. You don't need a screwdriver, but a short section of a paper clip will do. I just set the band on a raise surface to allow room for the pin to be pushed out using the paper clip. For this watch, one side of the pin resembles the slotted side of a small screw - but it is not a screw. This is the side that bulges up a bit to help the pin stay in place. I believe if you punch it out from the opposite side it will fall off quickly, but if you do from the bulged side it, too, will come out but with some resistance. To reattach the band you need to punch the pin into the slot in such a way that its bulged side is on top otherwise you may end up with a bent pin. You must also first line up the hole with the paper clip before reinserting the pin. Good luck.
