Televison & Video Logo
A
Anonymous Posted on Mar 17, 2017
My Hitachi tv model # le55a6r9a has a black screen. What do I need to do to fix it? It does have a picture when I shine a light on it when the room is dark so I think its the backlights.
Mandy Stuart Webb
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 01, 2017
Mandy Stuart Webb
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1624
Points
I have the same problem only mine doesn't have any picture even with a light on it.
5 Related Answers
Anonymous
  • 87 Answers
  • Posted on Jan 12, 2009
SOURCE: I have a phillips magnovox
The coolant fluid in the blue and green picture tubes is in need of changing.Unless you have done this before I do not recommend that you attempt this repair.A shop shoud be able to make this set look like new again for about $275
Anonymous
  • 56 Answers
  • Posted on Feb 17, 2009
SOURCE: vizio p42 very dark screen backlight off
There is no back light in plasma TV, Base on the description, the Z Sustainer board is bad. Replace the board will fix the problem.
Anonymous
  • 41 Answers
  • Posted on Apr 29, 2012
SOURCE: Sony cyber shot dsc-t10 backlight not working
Yes, the backlight is a separate part. It can be removed from the LCD and replaced.
The following video shows how to replace the backlight in a Sony camera.
http://www.desmontalo.com/?p=275
Anonymous
  • 14553 Answers
  • Posted on May 06, 2012
SOURCE: How to fix fix my Hitachi Projection TV - model # 61WX01W, got darker and darker and now all dark. Has 3 pictures tubes. How do I fix the problem?
Likely what you have is the three tubes each have a filament--not unlike a light bulb-----someone would have to trace the filament voltage (usually comes from power supply) from source to the three tubes---filament connects to each tube with two connections and is usually 6.3 volts.
Anonymous
  • 14553 Answers
  • Posted on May 22, 2012
SOURCE: my Sony model KDL-40S4100 is dark. I have a picture and can see whats going on, but the screen is just not bright. I'm thinking that its the backlight, but how can I tell for sure??
The only way to tell if a backlight (if set has one) is bad is to measure the voltage on the power board and at the back light itself---most voltages are marked on power board or a Service Manual would pinpoint them.
If the voltages are normal and back light is on but DIM only option would be to replace the board that drives it or the actual back lights'
If you Google the model number with "parts" you should be able to locate the back the parts involved.
Hitachi LE55A6R9 / LE55A6R9A need a back-light inverter, Which one do I have to order?
Contact the authorized service center for Hitachi, to get more details.
2answers
I have sound but only a black screen on my Hitachi LE55A6R9 TV
Base on my experience. It's time for new one.
Fix it or replace parts will end up more then new one.
Good luck
Mai
Sound but no image on Hitachi 42pd5000
Two things need to be checked. The ballast board and the T-con board. Shine a flashlight on the screen with the TV on...If you see a faint picture moving, then the T-Con board is OK. The ballast board for the white backlight is bad. If you don't see a faint picture, then the T-con board is bad. You can get parts here: www.shopjimmy.com TV Parts Universal TV Stands DLP Chips ShopJimmy
Hitachi le55a6r9a has audio but no picture. When you shine a flashlight on the scree, you can see a dark image. Which piece needs to be replaced?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
I need to know where to locate the back light inverter for a Hitachi LE55a6r9a hdtv.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
