Question about Hotpoint Ultima WF860 Front Load Washer
Heater element wiring for hotpoint wf860p washing machine on the control board end
The two wires pulled out of the control board one has a plastic shroud on it. They can fit either way. I just need to know which one goes where.
SOURCE:
  • 209 Answers
SOURCE: hotpoint wd62 washer dryier (aquarius 1200)
i am a retired engineer of 20 years, and its about a year since i worked on combination washer/dryers but if the heater elements fine and power comes from timer there must be cut out somewhere around where it should warm up, look all round the machine one may be hidden or hard to spot there maybe about 3 one of them one of them could be a trigger device (you can press a button to reset it) that style is a very small cube about the size of a sugar lump with2 spades on it, others look like a small flat oval or round shape the size of a five pence piece with 2 spade wires on them, remove the plug from wall and remove these spades and check the contacts for continuity, you need not remove from machine to do so, no circuit + no heat, replacement item not expensive, thats where to start based on the information given, check the sensors you mention again, it sounds like your so close, good luck and work safe
Posted on Sep 09, 2007
SOURCE: wf860p computer control automatic
I have had this problem it is caused by accidentally pressing both the on and start button together. It puts the machine into demo mode. You need to press both the buttons together again for about 30 seconds. If it doesn't work first time switch the machine off and do it again. Sometimes you have to do this many times before it works but eventually it does work.
Very frustrating.
I found the cause was either leaning on the front of the machine or resting a broom which when you pick it up accidentally presses the two buttons.
Posted on Nov 22, 2007
  • 4 Answers
SOURCE: HOTPOINT F-01 error code
Try http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Feb 16, 2008
IFIXALL
  • 869 Answers
SOURCE: Wiring Diagram
Have you looked under the main control panel for this??The other way is to contact Hotpoint(GE) support,they will have this information.Just have model & Serial number ready.
Posted on Jun 03, 2008
barkencoa
  • 3463 Answers
SOURCE: plastic lug securing paddle in drum have broken off
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
Posted on Dec 29, 2008
Not cold, freezer is working not the refridgerator
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 Phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrigerator's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Using a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Hope this help in solving the problem.....
May 09, 2011 | Hotpoint Refrigerators
Freezer freezing bottom not getting cold
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrigerator's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Using a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the advisable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Take care......
Aug 16, 2010 | Hotpoint HTS18JBPCC / HTS18JBPWW Top...
Bra wire stuck between the drums in hotpoint WD440 Aquarius washer dryer
Look all around the inner tub with a torch , if you spot the wire sticking through grasp it firmly with pliers and pull out , dont let it go , if it slips completely between drums it is more difficult to get to.
Nov 08, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint WD860P trips rcd within second of being switched on
the usual problem with tripping is the heater of the dryer box has become loose and touching an earth.
if you take the lid off you will see the box on top of the drum.
with the electric off you can look for loose/disconnected wires and wiggle the 2 metal tabs that are the ends of the heater, should not move.
you may be better with an engineer visit if it's not an obvious fault.
Feb 25, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Change heater element on a Hotpoint Ultima WMA66P
I am assuming you have accessed the element, in the centre of the element is a fixing nut, remove this altogether, and lever element out with a broad blade screwdriver or similar.
Pull the thermistor out of the element, and transfer to new element.
Also transfer stainless steel fixing bracket to new element if there is one fitted. Refit new element
Thamks.
Jan 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Need to remove case of hotpoint wma 63
The drum comes out through the front on this one.Take off kick plate and remove screws holding front panel to frame. Take out soap drawer & remove screws behind it. Take off band holding door seal & peel seal back.Remove 2 screws holding door lock &push lock through. Pull control panel forward at left side &slide to right to remove being carefull with board & wiring.Remove screws holding top end of front then lift slightly &remove front.Remove back panel &take wiring off heating element & pump. Disconnect the pump hose at the drum end, disconnect the hose from the soap dispenser, note that wiring is fastened to the drum at several points and will need to be disconnected. Remove panel from behind control board then carefully move everything away from the front of the machine, the drum can now be lifted clear.
Forgot to mention unplugging motor but common sense will prevail.
If you need any further assistance please post back
Good luck & thanks for using Fixya
Nov 27, 2008 | Hotpoint WMA64 Front Load Washer
F01 flashes and machine not work.WF860P
motor triac short circuit check motor and module connections, if o.k poss motor fault
Jan 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Aquarius 6kg wma52 blows main power breaker
yes check for a heater element down to earth or at least a wire on the element off and touching the case, but i am confident its a heater element, rate me when you fix it, work with safety unplug when working on machines
Sep 16, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Washing machine probs
right you have 2 parts for heating the water you have the heater element you can test this simply by undoing the wires making sure to wright down order they go in get an old wire with a plug on the end attach each colour in the order you took the proper wires of plug it in if the element is working then you will feel the heat and see it glow if it doesnt then its a faulty element if it does then it will be your thermostats both element and thermostats are located at the front behind the front panel this needs taking off
Aug 16, 2007 | Hotpoint First Edition FEW12 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
