How do I turn off the child lock on my Electrolux washing machine?
On earlier Electrolux models, this function should not have been enabled, but it can be disabled/enabled by simultaneously pressing the two buttons to the left of Start/Pause and holding them down for about 5 seconds, when the "padlock" symbol will illuminate (enabled) or extinguish (disabled).Feb 25, 2019
Hi Daren Deen,
I think you can send them an email at [email protected] and they would create a ticket for you and they will give you detailed instructions on how to reset it.
Program the machine for white wash and turn down temperature and duration manually, and tune up the sentrifuge program to maximum RPM.
It helps to use a machine with large drum and minimum 1600 RPM. Large diameter of the drum is more efficient than a small diameter drum at the same RPM.
This is the manual on your machine. Unfortunately there is no info on the blinking light so I am assuming that it is a delayed start. Now remember this is a high efficiency machine so it may not seem like it is doing anything when it is. As far as the drying part is concerned, check your drying temp. selection.
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
took the plate of just under the door removed 2 screws then took the black rubber boot that hooks up to the pump and cleaned out the **** that was stuck in there, pluged washer back in after a little crunhin noise everything was back to normal
Company:EKL Appliances Limited (not a subsidiary of AB Electrolux)Address:Global Business Park, Tower-A, 3rd Floor, Mehrauli - Gurgaon Road, Gurgaon - 122 002Tel:(91)-124-280-3250/280-3260Fax:(91)-280-3292
Got Backup?
