Mercury Master
- Posted on Jul 23, 2009
Re: FUZE BOX DIAGRAM FOR 1990 MERCURY TOPAZ
Replacement
- Access the fuse panel from the left of the steering column.
- Locate the blown fuse and pull out. DO NOT TWIST.
- Take note of the ampre number written on the top of the fuse.
To install:
- Push a new fuse of the same ampre into the receptacle, making sure the contact is being made on both sides of the fuse.
LOCATIONS
Headlights and Highbeam Indicator
- One 18 amp circuit breaker (22 amp in 1987 vehicles) incorporated in the lighting switch.
Front and Rear Marker, Side Parking, Rear and License Lamps
- One 15 amp circuit breaker incorporated in the lighting switch.
Windshield Wiper
- One 4 1⁄2 amp circuit breaker located in the windshield wiper switch.
Power Windows
- Two 20 amp circuit breakers located in the starter relay and the fuse block.
Power Seats and Power Door Locks
- One 20 amp circuit breaker located in the fuse block.
Hazard Flasher
REMOVAL & INSTALLATION
NOTE: The hazard warning flasher is located on the rear side of the fuse panel.
- Locate the hazard flasher in the fuse panel.
- Pull the flasher out. DO NOT TWIST.
To install:
- Push new flasher into place making sure a good contact is made with both terminals.
- Test flasher to make sure they function properly.
Various Relays
LOCATION
Cooling Fan Controller
- Located behind the left side of the instrument panel.
Cooling Fan Controller Module
- Located behind the right side of the instrument panel.
Cooling Fan Relay
- Located in the air conditioning cooling fan control module.
Electronic Control Assembly
- Located under the left side of the instrument panel.
Electronic Engine Control Power Relay
- Located behind the glove box on the right side of the instrument panel.
Fuel Pump Relay
- Located behind the glove box.
Horn Relay
- Located in the fuse block.
Fig. 1: Main fuse box located on driver's side to the left of the steering wheel, above the brake pedal
This is the best info I could find....I hope this helps ya!
horn fuse
