SOURCE: need more talkpower without a linear amp
Send it to a CB shop and ask em to peak it and tune it,shouldnt cost more than 75.00
SOURCE: galaxy 98vhp no modulation am
Turn up your mike gain. Mod the beans out of it and that should fix your problem. Crank every screw you can see on the board and wash it out with soap and water. This will fix it good.
SOURCE: Galaxy DX 98VHP meter stopped
You appear to be aware of you antenna system with the separate meter attached so the tells me you dont punish a radio with an high swr. I am just guessing red wire/solder in mic cord at plug given that it is a side mic mic jack.
Stock mic
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
SOURCE: How many ohms should my coaxial cable be rated for a galaxy 98vhp
radio 50 ohms ,antenna 50 ohms and coax 50 ohms .
