Vacuums Logo
Colin leyser Posted on Mar 16, 2017
My karcher steam cleaner filler cap won't unscrew even when cold
5 Related Answers
Martin Grech
  • 94 Answers
  • Posted on Jul 29, 2009
SOURCE: Karcher SC 1502 steam cleaner can't get cap off water tank
Dear jrider784,
I solved a problem like this on FIXYA, just a few months ago. I gave this solution. Try to fill the machine from somewhere else. You can do this from the outlet. If you manage to do this, put on the machine. ( now you know that when there is hot water in the machine, the tap goes round free for safety). Now as the water starts to cool down....start trying to see if you can unscrew it. My plan is that with the hot water, the safety will start to work again. If the cap does not release the safety on cooling, then there is no other way but to destroy the cap and replace with a new one. Very important to mention that this job must be done by a qualified technician or some one who knows what he is doing. Working with hot water is very dangerous.
Regards,
Fulltech.
Anonymous
  • 4088 Answers
  • Posted on Sep 09, 2009
SOURCE: Steamer filler cap is sealed
You need a little more leverage--either a strap type tool or a pair of adjustable width pliers that span the width of the cap. Try running hot water over the cap first which may loosen it enough to remove by hand.
Anonymous
  • Posted on Jan 22, 2010
SOURCE: i cant unscrew the filler cap for my polti 950
I had the same problem with the 2400 model, because the filller cap is a safety cap it thought there was pressure in the tank so wouldnt unscrew just kept going round and round. It had a little water it it. I switched it on heated it up then switched it off and let it cool a bit. There was a small metal bolt on the underside of the tank which I could unscrew with a alan key. This let the pressure out, I then rinsed it out with cold water and hey presto the safety value released itself. hope this helps
Anonymous
  • 438 Answers
  • Posted on May 07, 2010
SOURCE: DE4002 Steam Vacuum: Is there a manual for The Karcher DE4002 steam cle...
Hi There,
Here's a link to the owners manual for your Karcher DE4002.
If you found this information helpful, please be sure to rate the repair helpful, or leave feedback. This is really appreciated.
Owners Manual For Karcher DE4002 Steam Cleaner
Anonymous
  • Posted on Jul 24, 2010
SOURCE: I have just used the karcher steam cleaner and now
you need to even the canister pressure. Release the valve from the handheld device, i.e. it needs to be plugged in and pressed. Presure also exists at room temp.
Do you sell a water reservoir filler cap for the Shark liftaway steam cleaners model S3901
We aren't Shark, we are FIXYA and we don't sell anything.
Here you go
https://www.google.com/search?q=water+reservoir+filler+cap+for+the+Shark+liftaway+steam+cleaners+model+S3901
Water Tank Cap (1082SO) ' Official Shark® Replacement ...
https://www.sharkclean.com > parts > all > water-tank-cap
Description. Replacement water tank cap for the Shark® Professional Steam Pocket® Mop. Works with these models: Shark® Professional Steam Pocket® Mop.
US$4.95
Where can I purchase a safety filler cap?
See Google.
[PDF]steam cleaner - Pdfstream.manualsonline.com
pdfstream.manualsonline.com/.../e7f63cef-798e-41f3-bec7-5e43d5da5d...
When using your Steam Cleaner basic safety precautions should always be ... not screw the safety/filler cap onto the .... When using the Ultra Steam Shark II with.
My Euro-Pro leaks steam at the filler cap. It is tightened down but still leaks. Have replaced the rubber ring in the cap but still leaks dangerous pressure steam.
take cap off remove gasket get clr calcium lime rust cleaner put cap in cup of clr give it 4 or 5 min remove rinse replace gasket, empty tank fill with distilled water not tap water no from now on use distilled water only.
Oct 18, 2014 • Vacuums
Cannot unscrew filler cap from steam cleaner SC 1.020
Get under it with something like a butter knife and lift with the knife while you turn it.
2answers
Karcher steam cleaner safety lock won't open
You might want to plug it in but not start it. This might unlatch the lock.
May 06, 2013 • Vacuums
4helpful
Hi There,
4helpful
2answers
I have just used the karcher steam cleaner and now cannot get the safety top off. Rio
i cannot get the cap off my karcher sc1122 even though its cooled down
15helpful
4helpful
Dear jrider784,
Regards,
Fulltech.
Top Karcher Vacuums Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
