Hello sir; It don't need to anything but reset, the procedure as follow; press "clear" 'exposure" "clear" "exposure" then press 14 hit print, it should take care of you, good luck.
So I thought that I should hit the green button 14 times but what you have to do is press clear (red button) then the exposure button which is way on the very left side and then the red button again until everything goes blank. then you press the number of print pages until it shows 14 and then you press the green print button and then it resets itself and now it is working perfectly. :) thanks
I see the user manual says contact your SHARP service center immediately and is no further help. But a bit of websearching revealed
Error Codes Starting with "H" are fuser faults.
H2-00 Fusing unit temperature error
H3-00 Overheated fusing unit
H4-00 The fusing unit doesn't heat up
If you haven't got the user manual it is here:- http://www.sharpusa.com/files/cop_man_AR162S.pdf
Importantly it shows how to release the fusing unit. If you cant see an obvious problem then you may need to get a new fusing unit.
You may need to reset the copier to clear the error so it can try starting again when you switch on.
