Question about Yes Televison & Video
I record Yankee games from the YES network through the spectrum cable dvr onto dvd, i am now geting an error message saying cant record in plus dvr mode, what can i do about this?
SOURCE:
Bluehound
  • 27 Answers
SOURCE: I cant record DVD's
If you mean burn a movie from the HDD to a DVD. It will only let you do this once.
Posted on Jan 11, 2008
SOURCE: Error message
Try using suggested DVD media as suggested by Toshiba. DVD-R, or -RW, 4-8x, Fugi, Verbatim, or Kodak. When writing DVD, include All pretest. Seems to work for me so far.
Posted on Mar 04, 2008
  • 4 Answers
SOURCE: Connecting my DVD Recorder to Dish Network so I can record
If it is hooked up right to record as the program is on. Then make sure the input is set correctly, the tv should show pic from ext-1 the e-55 should be on channel 3. This should solve ur problem.
Posted on Mar 14, 2008
SOURCE: Error message: Can not record on this disk???
In many devices, DVD-R and/or DVD-RW discs do not work. You must use DVD+R or DVD+RW discs. Good luck!
Posted on Jun 05, 2008
  • 4 Answers
SOURCE: Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Posted on Jul 19, 2008
Since my comcast switched to digital I cant record !! Is this DVR compatiable with Comcast digital cable???
Yes,all DVR compatible with digital signal that included Comcast digital cable.U can't record because probally the program u tried to record it copy write protected.What did u tried to record?Just tried to record some plain show,If it is recordable than u know the deal.
Feb 02, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
Will not record and also keep geting error nodisk
Did you try a disc cleaner? Maybe the lens is just dirty.
Jan 03, 2008 | Televison & Video
I have surroundsound. I have dish network with hd dvr. I have a sony bravia hd tv. I have a dvd player, and cd player. I have a magnavox dvd recorder. I want to record from my dvr to my dvd recorder. ...
To get the functionality you're looking for you'll need to to take the cable running from your DVR output and connect it to the input on your DVD recorder. Next you want to connect a cable from your DVD recorder output and connect it to your TV. If this is an HD set up you want to use HD Cables for all of the connections.
Daniel Busa
DISH Network Customer Service
Jan 03, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
This program is not recordable in +vr mode, this is the error message, i am trying to put my programs that are saved on my comcast dvr onto disc, the manual says these are "copy-once" programs, what does...
This means exactly that these are copy Once only, meaning you can not make it copy say 10 copies, at the same time, it means you must do one a at a time. If you wanted say 10 copies, you must do the entire process over and over.
Apr 02, 2010 | Toshiba DVD Recorder
How do i record from directv hddvr plus to my vcr or dvd
Your going to need a AV connection out of the DVR into the DVD or VCR, whichever you want to record to. Go with the highest quality cable you can because that will define the quality you end up with. If you have an HDMI connection out of the DVR and an HDMI connection into your DVD Recorder, that is definitally the way to go.
Oct 25, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
No signal
how do i connect a usb stick for a ch usb dvr to a video player
Jan 29, 2009 | Cyberhome DVR 1600 DVD Recorder
Verizon DVR HD Cable Box
Press the red button tha has a text of REC
Jul 13, 2008 | Televison & Video
Error recording
It is the disc type that your using or the lens of the disc. Although this unit can use x16, dont. Use x8 and make sure it just says x8. I can assure you it will work hands down. I have this unit. It runs strong since jan 06
Jan 14, 2008 | Philips Magnavox MWR10D6 DVD Recorder
DVR to DVD Recorder
Hello Steve,
I know what you are asking for, and yes it can be done but not how you want to do it. The DVD recorder has coded into it software that prevents the DVD recorder from copying copywritten encrypted material (Video Cypher or Macrovision). What you need is another device to prevent the effects of the encryption (a company called SIMA makes devices that do this) the DVR would connect to the SIMA device and then to the DVD recorder.
I hope this helps,
Thank you,
Shuttle83
Oct 14, 2007 | Directv Plus DVR DTV Receiver / 100-Hours...
Televison & Video Logo
Top Yes Televison & Video Experts
Marvin
Marvin
NOEL
NOEL
ray gallant
ray gallant
Are you a Yes Televison and Video Expert? Answer questions, earn points and help others
