Question about Puma Watches
How to set/adjust Day of the Week on Puma Vertical black display quartz black watch
The Date on my watch does not tally with the Day of the week on my watch. How to adjust it back? This happens when I adjusted the date 2-28 to 3-2. Example: today's date shows 3-14, Day of week: THU. My manual does no show how to adjust this.
SOURCE:
  • 14 Answers
SOURCE: Watch has correct day and date only 1/2 each day
The watch thinks at Noon it is really midnite, so you must scroll 12 hours ahead to repair this. There are usually 2 "clicks" on the stem of the watch when you pull it out, 1 will set time, 1 will set the day/date, be careful to pay close attention to which is happening when you pull out the stem, and setting should go well after that.
Posted on Dec 01, 2007
  • 29 Answers
SOURCE: Setting time on Seiko watch 7N43
Mike 1935 if your watch has hands only & no digital display the crown where you set the watch pulls out half a click to set the date and should pull out a little further to set the time try that.
bjbc I am assuming your seiko watch is a digital watch. Try holding in the top rt button if its the watch I think it is it should change to 12yr time.
Posted on Mar 10, 2008
escapement
  • 2338 Answers
SOURCE: how to adjust day date on older rolex perpetual day date watch
There isn;t any downloadable manuals for Rolex watches, but operation of Rolex Day-Date is very simple:
1) when you unscrew the crown, it is in winding position,
2) when you pull out the crown to the first click, it is in day and date setting position (depending wich way you turn the crown).
NOTE: to adjust the day or date, previously you have to advance hands forward, passing 12 o'clock (midnight) mark and stop advancing at 4.00 a.m. using the crown in position as described in chapter 3. When done - push the crown fully in, then pull out to the first click and only then adjust the day or date.
3) when you pull the crown further out to the second click, it is in time setting position.
To find the daytime or night time on the watch: pull out crown to the second click and advance watch hands forward till you pass the 12 mark on dial. If the date changes as you pass it - it is the night time (midnight). If the date do not change as you pass it - it is the daytime (noon).
After all settings being done, allways screw the crown back down as it protects the watch from water and moisture.
Never use watch in sauna- it's not designed for that.
Do not forget to rate, please.
Posted on Mar 07, 2009
escapement
  • 2338 Answers
SOURCE: SETTING (DIGITAL) DAY/DATE ON THE FOSSIL JR9387
Follow this link and download proper instructions:
http://www.fossil.com/webapp/wcs/stores/servlet/StaticView?langId=-1&storeId=12052&catalogId=10052&page=Instructions&nav=custCareNav
Rate me, please.
Posted on Mar 24, 2009
  • 3 Answers
SOURCE: adjusting Date and day on a Festina 3 dial watch
Alhamdulillah, the problem solved (at last) tks to IRONMAN (http://www.fixya.com/support/t579677-instructions_mens_festina_watch_16095#SameProblemContinued)
The steps are like this :
1. Pull the crown full, and turn it clockwise until you find the right day.
2. and then push it one click (dont push it to hard so it back to normal position) and turn the crown counter clockwise to adjust date.
3. Push the small button near the crown to adjust month.
and voila... the problem solved
Posted on Jul 05, 2009
Setting timex analog mens watch with small window in face of watch indicating day of week, I think
Lots of older watches needed to have the hands advanced 24 hours to advance the date one day. Fortunately most modern watches require the hands to be wound backwards to advance the date, often at the rate of a day per hour. A combination of the backward and forward winding of the hands made adjusting the day and date much simpler and quicker.
A few premium watches had a third position when pulling out the winder, a position dedicated to adjusting the day/date
Jun 16, 2016 | Timex Watches
Tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 | Watches
Tip
on Jul 09, 2010 | Watches
How do I set the DAY of the week on my new watch, Akribos XXIV Women's AK560RD Quartz Multi-Function Genuine Leather Watch ?
There are three positions for the crown. You can pull it out all the way to third position and turn up or down Each of those turn one sub-dial. then you can push back one position and again up or down. Each of those turn another sub-dial hand.
Sep 17, 2015 | Watches
How do I set a Danbury pocket watch with date display
If it is this pocket watch, then the crown (the bit you turn to wind the watch) has 3 positions. Position 1 is when the crown is pushed in all the way. Position 3 is when the crown is pulled out as far as it will go. In between position 1 and position 3 is a place where the crown will stop, this is position 2.
To set the day of the week, pull the crown out to position 3 to set the time. When you set the time, the bottom dial with also turn to set the hour on the 24 hour clock, if you turn the crown enough to cycle through a whole day the day of the week dial will also turn. Keep turning the crown until the time is set on the proper day of the week.
To set the date, pull the crown out to position 2, and turn it clockwise until the hand on the date dial points to the correct date.
Hope this helps!
Sep 01, 2012 | Watches
I can't set the time on the Timex 1440
To set the time on your Timex 1440 Watch, please follow these directions:
1. Press and hold MODE (Upper left button)
(HOURS will flash and you'll be in Alarm Mode).
2. Press MODE again to enter TIME mode.
(SECONDS digits will flash.)
3. Press ADJUST (bottom right button) to set SECONDS to zero.
4. Press START/STOP (upper right button) to select MINUTES
5. Press ADJUST to change
6. Repeat to set Hours, Date, Month, and Day of the week.
(Go through 12 hours to set AM or PM)
7. Press MODE when finished
8. To display DATE from TIME display, press START/STOP
9. With DATE displayed, press and hold START/STOP, then press ADJUST to change display between DATE-MONTH
10. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12 and 24 hour format.
I hope you are now able to set the time on your watch! If you appreciate these instructions, please remember to rate this post.
--Sandy
Apr 18, 2011 | Timex Watches
How do I change the time? How do I shut off the alarm?
http://assets.timex.com/user_guides/W163_M504/W163_M504_NA_EN.pdf
A. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode). Press MODE again
to enter TIME mode. SECONDS digits will flash.
B. Press ADJUST to set SECONDS to zero.
C. Press START/STOP to select MINUTES.
D. Press ADJUST to change.
E. Repeat to set HOURS, MONTH, DATE, and DAY of WEEK. Go through 12 hours to set AM
or PM.
F. Press MODE when done.
G. To display DATE from TIME display, press START/STOP.
H. With DATE displayed, press and hold START/STOP, then press ADJUST to change display
between DATE-MONTH and MONTH-DATE.
I. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12- and
24-hour format.
R Huff
Oct 24, 2010 | Timex 1440 watch
Setting Date & Day
Two clicks to the dial on the right. First click adjusts the day of the month. To change the day of the week pull out to second click and go forward or backward in 'time' and week will follow.
Apr 11, 2009 | Watches
Setting day and date on timex watch
For the analog Timex Indiglo with both day and date (CR 2016 Cell on back) and only the single crown available you must first pull out the stem and turn through the hours 24 at a time to get to the correct day(MON,TUES,etc.). Then you can pull the stem out only half way and set the date (1,2,3,etc.). Be careful to attend to the AM/PM time as you turn the stem for the day. Go too far and the day will change at noon and you have to wind through seven more 24 hours to correct it.
Nov 26, 2008 | Timex 27191 Wristwatch
Watches Logo
26 people viewed this question
Top Puma Watches Experts
Arturs Kalnins
Arturs Kalnins
Tom Chichester
Are you a Puma Watch Expert? Answer questions, earn points and help others
