Electrical Supplies Logo
H
Heather aguilar Posted on Mar 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a picture and location of the shut off valve on a mcculloch 5700 generator. I am trying to shut the gas off while I clean out the carborater because the gas is pouring out of it.
Lee Parker
Level 2:
Habit-Forming:
New Friend:
  • Expert 108 Answers
  • Posted on Mar 14, 2017
Lee Parker
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
108
Questions
Helped
28358
Points
342
How can I replace carburetor?
I believe the electric solenoid is a fuel shut off. solenoid needs energized, normally with switch 12 Volts. other then float bowls are the carbs. identical, if they are switch bowls, should work. If not you will have to add switched power to solenoid, the link below looked similar to yours.
Generac Generator Carb removal and disassembly
McCulloch Generator Model FG5700AK
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
1helpful
Pull start on a 5700 watt generator is locked up. Tech left the fuel shut off ON over night. It filled my oil up with gas. I drained all the old gas and oil out. Refilled it with 37 ounces of 5w30
Did you remove the spark plugs and drain the fuel from the cylinders? The gas in the oil was definitely a sign that the oil needed draining and replacement, but the pull start may be hydro-locked in the cylinders are full of fuel.
What would make a McCulloch FG6000MK 11 HP generator start and idle fine but not able to rev-up and generate power.
Have to an ultrasinic cleaning of the carburetor and see if that will clean up the problem,
Bad on parts though most are NLA. but a carburetor from a Honda 11hp horizonal might work on this Chinese Honda cloned engine.
Where can I buy a mcculloch 5700 generator carburator
if you can not find a carburator you may need to find a re-built kit on the internet.
3helpful
I have a Mcculloch 5700 watt Generator that needs carburetor rebuilt and can't seem to find parts. Any suggestions on where to get parts ?
Take the make and model #s to a lawnmower shop, they can get what you need, if they do not have it in stock. Also remember to check in tank strainer for restriction.
1helpful
4answers
McCulloch 5700, 11 HP Starts easy with 2 pulls and begins running fine. Then it start dying and back fires,revs up and down, back fires. Then will run normal for a few minutes and will start revving up...
Sounds like you may have a wire shorting out. Check all ign wires and make sure one hasnt rubbed through. Maybe take off your front cover and make sure something isnt shorting out your coil contacts. Hope this helps
Won't start.
Hi raw 28:
ther gas that was in the carb probably evaporated. you might tryt a little spray starter fluid in the spark plug hole or in the air intake of the carb, This might just get it running long enough to draw gas into the carb and get it self sustaining,
Good luck Loringh
Top McCulloch Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
