Barnett Crossbows Barnett Hellcat 175 Crossbow Scope Package Logo
James Hutchinson Posted on Mar 13, 2017
Nock to nock is 35"what size crossbow string do i need LP
pbickwermert
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Jan 08, 2018
pbickwermert
Contributor
Level 1:
New Friend:
Answers
22
Questions
0
Helped
20548
Points
35
? The nock is in the back end if your arrow or bolt. What are you referencing?
Want to replace nock sensor
Make, model, engine year????
How can i fix nock sensor
If there is no nock present after resetting the computer replace it.
2helpful
Crossbows. I need a Manual for the Bear/Jennings Devastator Crossbow that I have
you might want to check with hunters friend @huntersfriend.com this a archery shop that just might find what you need.they have a very large sourse of equipment.one of the best archery shop on the net.and they carrie bolts for cross bows.check there web sight out.they will help you if they can.great people there.
Sep 06, 2012 • Archery
Scanning beam is to right, then I switch power on. Then it jumps against the end position and says nock nock, what to do? belt goes slowly.
That sounds like a hardware problem. Please contact Lexmark Technical Support Center for assistance on this matter.
The scanning beam is not going to the left, it is always at the right and says nock nock, even if the belt is running slowly but maybe the belt runs wrong way.
unplug the printer and try to manually move the beam assembly to the left slowly. There might be an obstruction in the path of the scanning beam or some dirt causes it to stuck.
Bad nock but still has lots of power
If it has a true knock it could be a spun bearing or piston wrist-pin,this being the case you'll need to get in to the motor. One way to locate the issue, as to what cylinder, is to run the engine at idle in park with E-brake on; remove and replace one at a time the spark plug boots. If you find by removing one boot from a plug and the knock sound drops out this could most likely be the cylinder at issue. I hope this may have helped,
Tom
Top Barnett Crossbows Archery Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you a Barnett Crossbows Archery Expert? Answer questions, earn points and help others
