well i never heard of this brand and if you cant find info on line it would make me wonder.a bathroom is a big expense i dont think i would take the chance
Question edited for clarity.
Question moved to a better Category.
Get out your digital test meter and check the switch for continuity and operation. If that passes the tests, follow the wires and look for a relay that operates the pump. Also test the pump motor for resistance.
If the Spin button on your Aqualux 1200 Electrolux washing machine is not staying inside when pressed and comes out automatically after a few seconds, there could be a few possible causes:
Button malfunction: The button itself may be malfunctioning and not working properly. It could be a problem with the button's connection or the switch that it activates.
Control board issue: The control board is responsible for managing the functions of the washing machine. If it is malfunctioning, it may not be able to control the Spin button properly.
Motor or transmission issue: The motor and transmission are responsible for spinning the drum. If they are not working properly, the Spin button may not stay in.
Latch or door lock issue: If the latch or door lock is not working properly, it may not be able to keep the Spin button in position during the spin cycle.
How do you turn this on? If it is an air button that you push, it may well be the air switch in the motor is bad. The air switch is latching so when you push the button on the tub it closes the switch and lets the power go to the motor. When the button is pushed a 2nd time the switch will open and shut off the power going to the motor.
An air switch will cost about $21 to purchase.
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
I bought a new house and I have a jacuzzi bathtube . and all the sudden stopped working .. where or how I can locate the pumpe ? the only thing I see is the button to turn it on or off and now it does'nt go on ?!! I checked the circute praker and everything seems okay to me.... help please.
