Sewing Machines Logo
Julie Harrison Posted on Mar 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What are the correct settings for basteing on an elna excellence 730
R.A. Ellis
Level 3:
  • Elna Master 12,731 Answers
  • Posted on Mar 12, 2017
R.A. Ellis
Elna Master
Level 3:
Answers
12731
Questions
Helped
2618045
Points
59176
Here's a manual for your machine:
ELNA eXcellence 730 Instruction Manual
If your machine does not have a "basting" stitch selection, you make your own basting stitch by:
* Setting the stitch length to the maximum
* Loosen the upper tension so the bobbin thread lies flat under the fabric
Then to gather or remove the basting stitch, it is easy to pull on the bobbin thread.
1helpful
2answers
How do I set the machine to do a basting stich
if the machine can do a basting stitch the information should be in the sewing machine manual, if you don't have a manual, add a comment with the name and model number of the machine and someone should be able to help you find one.
or you can also try youtube for a video
What is the correct way to wind and insert bobbin in elna machine?
You always wind the Elna 7 hole bobbin with the holes on top, and load it into the bobbin case the same way, this means when you draw the bottom thread off the bobbin, it will turn anticlockwise.
How to clean and oil my Elna 730
there is maintenance tutorial on youtube
Basting stitch
Hi Laraine,
Take the time to go to your sewing machine store for proper instruction on the operation of your machine. Some are far more complicated that others....
I used a single cam in my Elna Carina and I can't remove it. help!
ELNA Carina Instruction Manual
Perhaps the spindle where the cam sets needs a drop of good quality sewing machine oil, like Tri-Flow Synthetic Lube. Be sure the stitch length & width are set to Zero.
Elna Carina Electronic SU Duplex Review
How to remove can from an elna Carina Its stuck and can remove it My...
1helpful
Trying to find a replacement foot pedal for an Elna XE32, as my mother's was moved to QLD (and now lost) when she went into an Aged Care facility, but the machine is still here in VIC!! Any ideas,...
I'm sorry I don't recognise this model number. But as you are in Australia, I would suggest that you ring Elna Australia and ask them for price and availability of the foot control you require. They should be able to either supply it or tell you the name of your local dealership.
http://www.elna.com/en-au/contact.php
Elna Australasia
1-15 Mills street
3192 Cheltenham
Victoria
Australia
icon_mobile.gif +61 1300 730 271
icon_mobile.gif +61 38586 3100
icon_printer.gif +61 1300 730 712
icon_mail_back.gif [email protected]
icon_home.gif http://www.elnaaustralasia.com
1helpful
I am wanting to set my machine (quilters dream 6603) for the best basting stitch I can. I am having trouble figuring out how to set the machine. Thanks.
I haven't been able to find a 6003 manual or a good image of the stitch range for this machine on line. However, a basting stitch might look like " . _____ . _____. " on your stitch selector. As your machine is targeted for quilters I'd have expected it to have a basting stitch in its range.
If there is nothing like that, then just dial up the longest possible straight stitch, ie take length up to 4 or 5, whatever the maximum number is. Then loosen off the top and bottom tensions and stitch away.
If you are using this to baste a quilt top, botton and batting together, I've discovered a product called "spray basting" which is fantastic and "glues" the layers together while you sew them. You need a big clear floorspace though and put paper down under the project. But it works great.
Trust this is of help to you.
How to set to baste
You would select a straight stitch and adjust stitch length to maximum length. And turn down the tension a little.
The Swiss Elnas had a basting plate that you used on a big wide zigzag and it would "miss" hooking the top and bottom threads together on one side so you ended up with a long straight stitch but with plenty of looseness to the seam.
But I've always found a needle and thread by hand is most effective, especially when attaching interlining to a silky fabric or velvet. Machine stitching would creep, but hand sewing would lie flat.
Top Elna Sewing Machines Experts
Mike Cairns
Mike Cairns
SmartAviator
SmartAviator
Ngoro
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
