SOURCE: Ms pacman from free play to pay play
You'll need to open the cabinet and locate the game board to make this change (be sure to turn the machine off first, and it's a good idea to use some sort of anti static device on yourself before handling game boards). Inspect the game board and you should notice a bank of tiny switches (these are called dip switches). If your game is in Free Play mode, switches #1 and #2 are both "On". Here's how you can change it:
Switch 1 Switch 2 Mode
Off On 1 Coin - 1 Play
On Off 1 Coin - 2 Plays
Off Off 2 Coins - 1 Play
On On Free Play
I hope this helps!
SOURCE: Ms Pacman/Galaga Cocktail Arcade//side 2 not working
1.Check the dip switches for cocktail set up/ no upright.
2.does the screen flip to the player 2? if yes
3.make sure you have good dc ground in player 2 joystick.
4.if no picture flip for player 2, go to solution 1.
Thank You.
SOURCE: Got a dedicated namco ms pacman galaga got a lot
Hello: first thing is check the 5V+ 12V+ -5V in the power
supply, sometimes when the power supply goes low or
high cause that problem, other thing that you need check
is the connector for the logic, sometimes contacts get
black, use a eraser to clean the contacts, the last thing
is reseat all chips in the logic, the ones that are in sockets
Thank You..
Miguel
SOURCE: I have a new Ms
PDF Manual at the link below.
http://www.namco.co.uk/PDF-manuals/namco-america-manuals/ms%20pacman%20galaga%20cocktail.pdf
Their should be a switch inside to activate the Test Menu.
Once in the Test Menu you need to go to '3 General Adjustments' and change the 'Credits To Start'.
You'll also need to select how many credits each coin is worth.
SOURCE: Namco plug+play poor picture quality
if it has multible colors the yellow has to go to the green top plug and red and white go to the furthist away from the green plug.
