I have no idea what toy you are referring to, as this is for computers and the like. But... It sounds like the batteries aren't delivering enough power or that the toys shorts out.
Try with highgain batteries and if that doesn't work, then I would complain about them to the store.
That or there might be a simple little switch you need to change so they don't go into sleep/off mode.
SOURCE: Receiver shuts offs automatically
Mine did same thing-when I put on my strongest reading glasses,I discovered ONE STRAND! of speaker cable was touching (-) speaker output terminal....felt like a fool....Worth taking a second look! [email protected]
SOURCE: My Mitsubishi turns off automatically...
I had the same problem with an RCA, check your sleep mode settings on it, it may have defaulted to 1 min, so it cuts off when it cuts on
SOURCE: Power turns off automatically
Same w/ mine. Repairman said they turn off auto to protect the set no matter what is wrong. Take it to be fixed. Mine was right at $100. Works great again.
SOURCE: the gps does not boot
Use with caution: This will delete your user data on the unit.
Try a reset:
(This worked for me when I had a similar problem.)
You could try a master reset;
Fair warning: I have not personally tried the master reset.
SOURCE: Kodak Z812 shuts off automatically
It is a high-powered camera, also knows as a GREAT camera. Use CRV-3 lithium duracell batteries. I have the same camera and the same "problem", but when I use that battery it lasts forever.
