SOURCE: bought a Jabra BT135 and lost instructions to install, please help
1. ok when the headset is off keep your finger on the botton until it goes blue (stays blue)
2.when gone solid blue search on your phone for bluetooth
devices and you should find it
3. then it askes for the pairing key type in 0000
4.when you play music while bluetooth hedset is on and bluetooth is on it should play in the headset
SOURCE: Cannot pair a7010 with Plantronics Voyager 520
The actual problem was Plantronics, I was not turning on pairing mode. I was confused with quick pair which starts not immediately after turning on, but you need to hold the button longer until led will start blinking blue and red.
SOURCE: have 3 jabra bt 135
Same thing happened to me. For about $5, I went to Home Depot and bought 24 gauge wire (about 5") and a pack of black heat-shrink plastic sleaves (1/8th inch or 3/16) from the electrical department. The 24g wire fits perfectly through the rubber slot after you pull out the broken ear hook. Use a pair of pliars to bend the wire to shape your ear (use the broken jabra ear hook as a template). Once you have the right shape and have filed down the sharp edges, slip the heat-shrink plastic sleave over the wire, making sure you leave the end piece that goes into the slot of the headset as bare metal. Use a hair-drier on high-heat to shrink the black plastic. Mine has worked perfectly for over a year and actualy fits better than the original.
SOURCE: i have a jabra bt 2050 that will not pair it only
YOu have to continously hold the power button, till the LED remains stable...
When you see the light stable, you can search for bluetooth dewvice in your mobile and pair ir..
When it as asks for pair code give 0000...
Now you can switch on your blueooth headset normally and now you can connect directly..
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
SOURCE: How do I put Jabra BT 135 in Discovery mode?
Turn the device on and continue holding the power on button until the light stays solid. That puts it in discovery mode.
Pair it with your device.
It will probably also ask you for the password to the bluetooth headset (mine did). The default is 0000.
