Did you ever find a battery? I have the same camera but NO ONE knows the number of the replacement and I have been searching for days.Did you ever find a battery? I have the same camera but NO ONE knows the number of the replacement and I have been searching for days.
You can't post conmments that contain an email address.
Sounds like the battery is faulty, or is not charging properly. Can you remove the battery and try it on another (heavy load) device? At least check with a voltmeter and put a (say) torch/car bulb across the contacts
o do this: Press the power switch. (Capture mode) Press the Play button. (Playback mode) Press the four-way controller (down). (Playback mode palette) Press the four-way controller (right) 3 times to select [Image/Sound Copy]. Press the OK button to display the screen for selecting the copy destination. Press the OK button to copy the data. Press the Play button or press the shutter release button down halfway to return to Capture mode. Playback Mode Palette Copy destination selection
* This function can only be selected when an SD (SDHC) Memory Card has been inserted in the camera.
All I could find out about this problem is that it has a lithium rechargeable battery, and so it could probably be charged through the usb port. If you take it into Best Buy, they can tell you for sure how it's charged, and which cable and port you should use.
Hello sir you can find one at Radio shack for 32.99or 3499 If its a PV-BP88 Camcorder Battery Both Manufactured by LENMAR The 23-287 battery is no longer made by Radio shack They use the Lenmar brand Thank you Matthew PS Google the battery part number and that will show you lots of places where they sell the battery online Thanks
We had the same problem.I went online and found some info after Googling the model number. There is a tiny SD card that goes into the SD adapter(this black small rectangle fits into a larger rectangle) a. When you insert the smaller one into the larger one, make sure the camera is off. I even took out my batteries and then inserted the card. It should work after that. Good luck.
YEA PLEASE CAN YOU HELP MEE BECAUSE MY Sylvania SMPK8854B WILL NOT LETT ME TOUCH THE SETTING AND I REALLY NEED HELP!! WITH MY Sylvania SMPK8854B!!
THANK YOU THEY MUCH!♥
