Tools & Hardware - Others Logo
D
Dale Deming Posted on Mar 09, 2017
How does the spring assemble to the collet lock on rotary tool model number 572.610031 ?
4 Related Answers
Anonymous
  • 202 Answers
  • Posted on Jul 07, 2009
SOURCE: Craftsman rotary tool doesn't lock down on the bits.
the collet is either the wrong size for the shaft on the attachment or is missing alltogether
Anonymous
  • 2176 Answers
  • Posted on Oct 03, 2009
SOURCE: Kawasaki Rotary Tool is missing the square collet nut
I am working on getting a website for this company, but you can try Alltradetools.com and see if they have anything, they distribute them.
Anonymous
  • Posted on Dec 07, 2009
SOURCE: Can't find replacement collets/locknut for PowerSmith rotary tool
Hello Bob, I recently saw your post about the Power Smith PS2103. I have this same tool, and have never been able to use it because the collets don't fit the bits.
I was looking at it recently - I have the owner's manual - and although there is no web address, there IS a toll free help line. Here is the number - 888-552-8665
I called the number - got their voice mail, left a message, but they have NOT returned my call!
The only outlet that MAY carry this brand is Zellers, but I haven't been there yet.
Good Luck!
Bob (in Canada)
[email protected]
Anonymous
  • Posted on Dec 21, 2009
SOURCE: I have a Durabuilt rotary tool model S1J-FE2-10
I have the same problem with mine. The collet nut that came with it is too big. It wont screw down to hold the collet. I am searching for a new nut.
I cant loosen the bit on my dremel variable 395. The hole that the 'stop rotary pin' enters which stops the shaft from spinning is stripped out. The pin will not stay in place when I attempt to unscrew the...
Clamp the bit in a vise or with vise-grips (you will probably ruin it) to hold it while you loosen the collet. You can disassemble the tool and get the lock assembly P/N 2615297356 from for less than $2.00. Search for the part number on line for a source.
How do you attach "multipurpose cutting kit model 565" to the dremel multipro model 395?
Remove the collet nut and collet then unscrew the sealing cap (black plastic ring), this has the same thread as the inner of the multi kit tool, so just screw on the tool then replace the collet and nut
3answers
How do you remove collet from porter cable router model 690 I have purchace a new 690 to mount to a mortise lock base and need to remove collet, the shaft threads onto the router where the collet is,
I would suggest going to Dewaltservicenet.com and typing in your model number for an owners manual for this tool. If you still need more help let me know and I will try.
2helpful
2answers
I have a Durabuilt rotary tool model S1J-FE2-10 that I can't seem to get to hold a bit. The directions say to hold the spindle lock button down and put the bit into the collet and tighten. I doesn't hold...
User Error! There are different diameter collets. I bet you are using a larger diameter bore collet than the bit outside diameter. Collet can be purchased at any hardware store. To remove unscrew nut, remove collet and replace with proper diameter.
1helpful
Flexible shaft not working all-in-one rotary tool
check and see if you have the right collet insert in the chuck if it is too big it wont lock the shaft. does the chuck turn? if so your collet is not locking the flex shaft
I have a Dremel 300, i think, lol.. standard Dremel... To losten the collet nut, you have to press down a button that locks the spindle so you can loosen it.. the spring and *** have stipped and it won't...
call dremel and ask for the part need you model number so have it ready Dremel Service Center Dremel Authorized Service 4915 21st Street 4631 E. Sunny Dunes Road Racine, WI 53406 Palm Springs, CA 92264 Phone: 1-800-437-3635 Phone: 1-800-275-2052 1-262-554-1390 1-760-327-3003
2answers
Good Luck!
Bob (in Canada)
[email protected]
1helpful
Dremel Moto-tool model 395 type 1 lock
You can either go to Dremel.com and type in your model number for replacement parts or call their toll free number at 1-800-437-3635 and get that information. Let me know if you need anything further
Dremel shaft lock spinning
Trying to fix a similar issue. The pin that gets pushed in by the button (and returned by the spring) seems to be fine. The hole in the rotating shaft that the pin fits into, however, is in the wrong place, so the pin never goes into the hole! All I need to do is somehow pull the whole front part of the shaft out about 1/16th of an inch, and it'd be fine. I just can't seem to budge it though. Any tricks, anyone?
Top Rotary Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Rotary Tool and Hardware - Other Expert? Answer questions, earn points and help others
