Watches Logo
j
james ferraro Posted on Mar 07, 2017
How to get back off of Disney Minnie Mouse kids watch
How do I put the back on my Lorus Minnie Mouse V52S-X002.
You need a watch back press if it is push on, or a back removal tool if it is a screw back..
https://www.fixya.com/support/r27181038-changing_watch_batteries
Large Disney Mickey Mouse Watch # MK1130 0613? BATTERY?
The simplest solution to this is to get a watch repairer to do it for you. They usually only charge a small fee to do it and just takes a few minutes.
If you can get the back cover off the watch the battery will have a size code marked on top of it, often an AG- or an SR- number. This will give you the size of battery you need. I think your watch has a 'push fit' back plate.
*Note* If your using something metal as a lever it could scratch the watch.
CAREFULLY using a blunt edged lever GENTLY lever the back plate off. This should reveal the battery. When refitting the back plate it should click into place using a firm, even and gentle pressure.
How can i set the time for a disney accutime watch LR626
Amazon.com: Customer Questions & Answers
www.amazon.com/ask/questions/asin/B00MA9D2XG
Amazon.com, Inc.Disney Kids' FZN3630 Frozen Anna and Elsa Watch With Graphic Band. by Disney ... Question: i have no directions for setting the time either in or on the pkg.Missing: accutime ‎lr626
Disney Kids' FZN3630 Frozen Anna and Elsa Watch With ...
www.amazon.com > Watches > Girls > Wrist Watches
Amazon.com, Inc.
Rating: 4.2 - ‎68 reviews
The digital time makes it easy for kid's to read. It light's up when you push it. The Frozen theme is adorable. This watch does not look cheap at all. It will adjust to ...
How to fix a plastic disney watch
Yes, you can solve your watch problem from ankaka . It is a great place of digital watch as well as many electronic products. Different modern types of digital watch and solution in case of problems are available here.
http://www.ankaka.com/Wholesale-led-watches_c10091
I have a Woman's Mickey watch that has "Disney Time Works" on the back of it. I would like to get a new band for the watch since after 10+ yrs it is very worn. The band is gold tone but it has not the...
mcdevito75 here, Any small watch repair shop can replace the strap for you. Ebay may have Mickey Mouse replacement straps if you"d like a Mickey Mouse strap.
I have a minnie mouse that was made in 1928! does any one no howmuch itz worth its called classic mickey!! please
mcdevito75 here, hello miss d, the first Mickey watch Disney came out with was in 1933, Mickey was invented in 1928, if this is a picture of your Mickey above, then it wa made in the early 1980"s. If it's working very well it could be worth a collector value of approx. $30.00 --$50.00
Top Disney Watches Experts
ADMIN Andrew
ADMIN Andrew
Simon Atkinson
Simon Atkinson
Don A
Don A
Are you a Disney Watch Expert? Answer questions, earn points and help others
