Kitchen Ranges Logo
Tanya Westby Posted on Mar 07, 2017
Some of the numbers on the key pad of my jenn-air dual-fuel slide-in range model JDS8850BDS stopped working....would the control panel be the problem?
4 Related Answers
Anonymous
  • 1314 Answers
  • Posted on May 24, 2008
SOURCE: jenn aire range model jjw9630aaw.
try pressing clock key
Anonymous
  • Posted on Jan 06, 2009
SOURCE: Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
Anonymous
  • Posted on Aug 12, 2009
SOURCE: Jenn-Air JDS8850BDS control panel malfunction
You need a new control board. I bought similar range in 2004 and I just got my 3rd control board. Heating the oven over 400 degrees and using the self-clean function kills the board.
Anonymous
  • Posted on Jun 01, 2010
SOURCE: Jenn-Aire Digital Control Failure
i am having the same problem. did you find a solution to this?
I have a jds8850bds and i have error code ef206 and m206 can you please help me
For the codes EE206 and M206 need to replace the Electronic Control Assembly this could also solve the EF206 code you have! Do you have a list of the codes in a manual?
4helpful
Our jenn air model js9860aab control panel buttons on the panel do not respond--is there a rebuild kit available to repair this -- because without these buttons, the convection oven of this duel fuel range...
no.. u must replace the touch pad assrmbly that whole unit.... i think u have a jds9860aab i believe... the part number u would need would be 74005750 it is for sale through sears at $272.00... u might need service.. u can take a look at part at repairclinic.com just type that part number in. ohhh also i believe this is a backordered part so most companies would prob take 2-3 weeks to get soo hope this helps..
9helpful
2helpful
2answers
Jenn-air jes9800AAB keeps buzzzing, front function panel flashes on and off
Your control panel is getting ready to quit. Mine did the same thing, I ignored it and now nothing on the touch panel works. About $150.00 for the part.
JDS8850AAS
Check wiring between keypad and Electronic Range Control (ERC). You either have a loose connection or something is shorted.
Electric panel not working
you have a common problem for that oven the key pad fails from wear try to find a replacement it should be fine after that.
Top Jenn-Air Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
